Old 07-18-2011, 02:08 PM   #1
al5759
My Ride: 2000 328Ci
misfire on 5 and 6 REPEATEDLY...HELP!
I have a 2000 328ci that blew a head about 4 years ago. Replaced the engine and was running great until just recently. It runs fine until in idle for more than 10-15 seconds. Idle drops down below 600 and shakes and then power is gone. I have to keep the rev up otherwise power goes away. To reset I have to turn the car off and wait a few seconds and it clears. I keep getting error code "misfire on 5 and 6". I have swapped coils, swapped plugs. No air leaks found. Swapped injectors and still showed misfire on 5 and 6 with 76% not present on 5 and 84% not present on 6. Nothing seems to be working and I can't figure it out. Last resort resort would be a cracked head...but I don't/won't go down that road again. Any suggestions on what else it could be???
al5759 is offline   Reply With Quote
Old 07-18-2011, 03:17 PM   #2
Zchild
My Ride: 2000 BMW 3XXi ZSP
I don't think it's a cracked head unless you have coolant in your oil. I would ask you if your Crankcase vent valve has been changed. It can become very brittle and leak and don't always show-up under normal vacuum test.
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 07-18-2011, 04:00 PM   #3
ZHud3
My Ride: black 323Ci
Just a guess but I had the same issue on my e36 and I ended up having to replace the coils, plugs and vanos seals to get it to stop
2000 323Ci
1992 325is Sold ):
1984 325e
ZHud3 is offline   Reply With Quote
Old 07-18-2011, 04:56 PM   #4
al5759
My Ride: 2000 328Ci
I haven't changed the crankcase vent valve yet. I will try that next. Thanks!
And I have already changed the plugs and coils, I will try vanos seals too. thanks guys!
