Aux Fan help! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 07-18-2011, 04:04 PM   #1
Rizhiy
My Ride: 2002 330Xi
Unhappy Aux Fan help!
Hi guys, I'm having some issues getting my Aux fan going. I got a 2002 330xi and its overheating in this hot weather and I think its mainly due to the fan not coming on.
I tested the fan separately and it works fine, so the first thought it was the lower coolant sensor that goes from the fan. Replaced the sensors and the fan still not moving. I start the car, try the ac and heat trick to get the fan going and its not responding.
Any suggestions on why it might not be going on?
Rizhiy is offline   Reply With Quote
Old 07-19-2011, 11:08 PM   #2
Rizhiy
My Ride: 2002 330Xi
Really? No ideas...
Old 07-20-2011, 07:01 AM   #3
Kubica
My Ride: 2003 325xi
Search for electric fan or e-fan threads. Best way is to try a buddy's fan. Also, it doesn't come on as consistently as you think.
I would scan codes for faulty thermostat or bleed your coolant. E-fan will throw a code too.
Old 07-20-2011, 12:55 PM   #4
Rizhiy
My Ride: 2002 330Xi
Thanks I'll check that
Old 08-03-2011, 06:23 PM   #5
E36graduate
My Ride: //M3
Curious how you tested the fan separately? I've had 2 E46's and replaced 2 Aux Fans.....you can bypass the control module and the fan will work, however it is probably the logic in the control module that is toast and you will have a few options as I have first hand experience:
1. Replace the fan with a new fan as the control module is part of the fan. $300
2. Do the same as #1 with a bone yard fan....$100
3. Bypass the broken control module with a trigger switch that you can manually turn on when car is getting hot. $ 0.50
E36graduate is offline   Reply With Quote
