Old 07-18-2011, 05:46 PM   #1
vtechthis
My Ride: 02' 330CI
Exclamation Aftermarket steel flywheel options
Im looking for a steel single mass flywheel for my 330Ci 5spd. Im looking for to get as close to oem weight as possible since im trying to avoid chatter and idle dip/stall issues associated with light weight flywheels. I was going to order the rogue engineering performance clutch/ steel flywheel kit but the flywheel is on backorder and I need a new clutch asap. My car is stage II supercharged so oem is not an option. Please chime in if you know of any other manufactureres who offer a steel flywheel for 5spd.
Something comparable to this would be ideal, slightly lighter than stock but steel.
http://www.rogueengineering.com/rogue/LTWF/PCS.html
vtechthis is offline   Reply With Quote
Old 03-11-2012, 04:10 PM   #2
mach.schnell
My Ride: 08/2000 330Cic x2
Well they now have steel at your link. !!
mach.schnell is offline   Reply With Quote
Old 03-11-2012, 05:42 PM   #3
Stinger9
My Ride: '04 330Ci
UUC doesn't have what you want?
And how about Turner?
Old 03-11-2012, 08:45 PM   #4
SLO Town
SLO Town's Avatar
My Ride: 2003 330Ci
Here's a good steel flywheel from JB Racing.
http://www.turnermotorsport.com/p-10...pe-z4-30i.aspx
Original Owner 2003 330Ci ZSP, 3145 lbs, 5-spd, leather, Alcantara wheel, 19x8.5" BBS, RE-11s, ZHP FCAs/diff cover/weighted knob, M3 eng + trans mounts/outer RCABs/RCABs with Turner limiters, Group N inner RCABs, Bilstein Sports (E36 M3 rears), Eibach P-K, H&R bars, BMW Performance Rotors, Turner caliper bushings, StopTech lines, Borla, RE pullies/RSM, Stewart WP, M-Technic Trunk Spoiler, Mason pedal/strut bar/end links, B&M shifter, UUC DSSR
SLO Town is offline   Reply With Quote
Old 03-13-2012, 12:04 PM   #5
hummer
My Ride: 2001 330CI
Turner installed a UUC steel flywheel and M5 OEM clutch in my 330ci. This flywheel is lighter than OEM but the whole package is only minimally lighter. I do have some gear clatter in neutral with the clutch released but only on hot days. I'm Ok with it! You might want to check out UUC's new dual clutch setup?
Old 03-13-2012, 12:16 PM   #6
TxZHP04
My Ride: ESS TS2+ ZHP
It's not compatible with a sprung hub clutch though so probably not something you want on a street driven car. Unlike most other JB Racing flywheels, this one also doesn't have a replaceable friction surface. I had considered this some years ago but decided against it for these reasons.
And for those who may be wondering, I've been running a stock clutch and flywheel with the ESS TS2+ SC'er for 4 years and 60k+ miles now. FI doesn't automatically mean that you need a clutch/flywheel upgrade.
clutch, flywheel, noise, swap, transmission
