Old 07-18-2011, 05:06 PM   #1
vinndubb
My Ride: 2001 330i
help needed...vanos question
Hey guys,
after doing some searching, seems like i am still confused. I want to do the vanos repair on my 2001 330i, so I bought the repair kit from Beisan. It only came with seals. What else do i need? And If I do , where can I buy? Do I need a gasket? Any advice will be appreciated!
vinndubb is offline   Reply With Quote
Old 07-18-2011, 05:23 PM   #2
vinndubb
My Ride: 2001 330i
Ok, I think I need the vanos gasket, and 2- oil/hose/pipe washer...
and they say I should also get valve cover gasket too. But where do I purchase these?
Old 07-18-2011, 05:27 PM   #3
Zchild
My Ride: 2000 BMW 3XXi ZSP
You need nothing else comrade, the kit is to change the VANOS seals in your VANOS unit. You might want to replace the valve cover gasket while you're in there as well as spark plugs if those things need attention. I think I did an oil and filter change when I did my VANOS seals. Just my two and a half cents worth...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 07-18-2011, 05:31 PM   #4
moiz21
My Ride: 1999 323i 5-SPD
You are correct. You need the vanis gasket and the washers at the very least. If you have never changed the valve cover gasket, you might want to get that as well. Since when you open up the valve cover, the gasket may be brittle from all the heat and break apart. Look at the top of this page for the sponsors. Most should carry what you're looking for. If not, try the dealer. But that is on the more expensive side.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 07-18-2011, 09:37 PM   #5
Sansho
My Ride: 2001 325i
As a suggestion, you should replace any seals involved, when you have it apart. See the diagram below, and consider replacing part numbers 11 (integrated seal on bolt), 17 (washerx2), 19 (vanos gasket), and any recommended on the Beisan Systems web site. If you do the valve cover gasket, also get the o-rings for each bolt on the valve cover gasket.
Sansho is offline   Reply With Quote
