Old 07-19-2011, 04:06 PM   #1
Kaboom
My Ride: 330izhp-6
Location of cabin air temp sensor
Anyone know? Search didn't pull anything up. Thanks! 04 330 with auto climate control.
Kaboom is offline   Reply With Quote
Old 07-19-2011, 04:09 PM   #2
jgold47
My Ride: 2004 X5 3.0
its the little slots on the front of the HVAC control. there is a fan that draws air across the sensor. it can clog up with dirt and need to be cleaned. There should be a write up or two, but its painfully simple.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 07-19-2011, 04:15 PM   #3
iansanderson
My Ride: 2001 330CiC
blow it out with a can of compressed air.
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline   Reply With Quote
Old 07-19-2011, 04:17 PM   #4
Kaboom
My Ride: 330izhp-6
How do you pull the face of the climate control off? Don't want to break anything! I have a new sensor here just to be sure. Thanks for the responses!
Old 07-19-2011, 04:39 PM   #5
jgold47
actually, I lied, its not that easy unless there is a way to get it out without removing the radio? If not, remove the radio following the instructions, then the HVAC control pops out . You can actually remove the fan assembly from the rear of the unit without disassembling anyting. Blow it out with compressed air, then I think I hit my sensor with MAF cleaner.
mind if I ask why you are replacing?
my about me link
Old 07-19-2011, 05:16 PM   #6
Kaboom
My Ride: 330izhp-6
Wow so I need to remove the entire nav thing in order to get the face of the HVAC unit off?
I was experience very occasional less than perfect climate control, so as is my style, I'm replacing the resistor pack for the blower and the cabin temp sensor. Not seeing an easy way to get this thing out, not much on a search, either.
Ian
Old 07-19-2011, 05:21 PM   #7
jgold47
The good News is that once the radio is out it's pretty simple. I wouldn't replace the motor just clean it
my about me link
Old 07-19-2011, 06:22 PM   #8
Kaboom
My Ride: 330izhp-6
It isn't the motor, just the sensor. Thanks for the help!
Old 07-19-2011, 09:21 PM   #9
zbi701
My Ride: E46 318i
Where do you get the sensor from? The sensor (some kind of thermistor) is soldered onto the HVAC module pcb.
zbi701 is offline   Reply With Quote
Old 07-20-2011, 11:23 AM   #10
Kaboom
My Ride: 330izhp-6
I purchased it from the dealer. It is a couple inches long and plastic. Anyone have any good pics on how to remove the climate control face? Changing that resistor for the blower definitely stabilized performance, even though it was working well before.
Old 07-21-2011, 09:09 PM   #11
zbi701
My Ride: E46 318i
Does it looks like #1 in the picture attached? If yes, it is not cabin temp sensor. It's outside or ambient temp sensor. Mounted under the front bumper driver side NOT inside your HVAC control module.
Name:	temp sensor.png
Old 07-22-2011, 08:17 AM   #12
AW325i
My Ride: 325i
I've cleaned the front of the sensor grill with a toothbrush, removed lots of embedded dust.
AW325i is offline   Reply With Quote
Old 07-22-2011, 05:55 PM   #13
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
You bought an outside temp sensor. Part number ends in a 133 doesn't it? If the outside temp sensor is missing or bad it can cause the compressor to not to kick on. There is not a replaceable interior temp sensor, at least not one made by BMW.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 07-25-2011, 11:59 AM   #14
Kaboom
My Ride: 330izhp-6
The part number I got was 64-11-6-930-015
My outside temp sensor is working just fine, I know they get hit a lot being in the fender. Also, my climate control is working fine too, I'm just anal about maintenence. I still haven't tried to put it in, but looks like there is nothing to put in.
Thanks!
Old 12-18-2016, 04:40 PM   #15
Med14187
My Ride: BMW 330xi
Kaboom, The part you have listed is the Heater core temp sensor. It engages the Heater Valve to open and allow coolant to flow through the Heater core.
Med14187 is offline   Reply With Quote
Old 12-18-2016, 05:55 PM   #16
hitbyastick
My Ride: 2002 325i
You can disassemble the climate control unit to more thoroughly clean the dust out. The motor is a brushless type consisting of a small flat squirrel cage fan wheel that sits on top of a post on the circuit board. To dissassemble the unit you need an electronics Torx screwdriver set. That fan wheel can cake up with dust pretty bad. At this point you can clean the little sampler grille from the backside which is more thorough. I put a tiny drop of pure Teflon oil on top of the post before I put the wheel back on top of it & reassemble.
Erryboddy got a plan till they get punched in the mouf - Mike Tyson
hitbyastick is offline   Reply With Quote
