Old 02-15-2009, 12:44 PM   #1
mujjuman
My Ride: not an E46
looking for DIY Differential fluid change....
I am looking for DIY Differential fluid change with pictures... I tried searching but so far I have found nothing. Maybe my searching skills arent the best. Please help.
I have the basics down...
Jack rear end up
find "fill" plug, unscrew it
unscrew "drain" plug, drain fluid into container
replace drain plug with a new washer
use a pump to fill 75W90 fluid
replace the fill plug.
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 02-15-2009, 12:55 PM   #2
kpeng
Banned User
My Ride: E46 330 and E30 325
Someone didn't look hard enough.
http://bokchoys.com/differential/diff_fluid.htm
kpeng is offline   Reply With Quote
Old 02-15-2009, 05:03 PM   #3
gregetski
My Ride: 2000 323 Ci, 2007 M
Here is one:
http://www.bmw325i.net/maint_rear_diff_fluid.shtml (hopefully the pictures will load for you. For some reason I am having some trouble with this website)
You are correct on the basics. Make sure you put the rear of the car on jackstands. This should give you enough room to get the hex into the fill plug.
I drove mine onto front ramps and then jacked up the rear and set the jackstands to make it level.
All-in-all this is quite easy to do.
gregetski is offline   Reply With Quote
Old 02-15-2009, 08:02 PM   #4
Albobmw
My Ride: 01 bmw 325i
Originally Posted by gregetski View Post
Here is one:
I cant open their pictures either.
Albobmw is offline   Reply With Quote
Old 02-16-2009, 09:33 PM   #5
mujjuman
My Ride: not an E46
Thanks for the links.
Yeah i found that site, but it would have been ALOT more helpful if the pics worked.
thanks for the link ken.
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 02-16-2009, 09:34 PM   #6
mujjuman
My Ride: not an E46
also, a bit of a n00b question but where can i get ramps? and how much are they?
and what jack should i use, the one that came with the car? i would imagine not...
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 02-16-2009, 09:36 PM   #7
kpeng
Banned User
Go buy a good jack from Sears or Harbor Freight. Ramps are available at any auto parts store.
Old 02-16-2009, 10:01 PM   #8
mujjuman
My Ride: not an E46
cool, thanks
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 07-28-2009, 05:34 PM   #9
MysticBlueM3
My Ride: 2005 M3, MT6
I got a 3ton jack + 2 jack stands combo for $125 from Lowes and have not had any problems with them
http://www.lowes.com/lowes/lkn?actio...3JS&lpage=none
I bought the heavy duty plastic ($46, 12K lbs capacity) ramps from an Advanced Auto store and they work great too!
http://shop.advanceautoparts.com/web..._T|GRP2042____
No problems with either set of products and I use them all the time! Hope this helps
MysticBlueM3 is offline   Reply With Quote
Old 07-28-2009, 05:36 PM   #10
mujjuman
My Ride: not an E46
yes it does. sweet. thanks!!
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 10-15-2010, 10:56 PM   #11
SDpnoy
My Ride: 330Ci and M3
Thanks for the links to the DIY
SDpnoy is offline   Reply With Quote
Old 07-21-2011, 02:18 PM   #12
Cobra
My Ride: '00 328i & '06 R6S
question; that DIY posted says that the car needs 2 bottles of gear oil, but some people have posted that 1 bottle is enough- so, which is it? i have the liqui moly gear oil, 2 bottles which contain 1 liter each.
Cobra is offline   Reply With Quote
Old 07-21-2011, 02:22 PM   #13
CylonRed
My Ride: '01 E46 330i sport
I believe I used just over 1 bottle...
CylonRed is offline   Reply With Quote
Old 07-21-2011, 02:33 PM   #14
mvrk10256
My Ride: E30 325i
its 1.1 L. So you need a little more than one bottle.
Old 07-21-2011, 02:34 PM   #15
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Bentley lists the diff for auto trans at .9 L (.95 qt.)
For Manual diff 1 L or 1.06 QT
M3: 1.3 L (1.37 qt)
Oil spec: BMW SAF-XO synthetic oil
Good luck reading the diff fluid threads...get OE if you can figure out how like me!
See me in June!
dmax on Facebook
Mangofy your E46!
Old 07-21-2011, 02:44 PM   #16
Cobra
^ thanks, dmax! yup mine is the auto. i wasn't able to find the oem fluid, so i bought 2 liters of the liqui moly fully synthetic 75w-90 gear oil. i figured it's german, so it's gotta be as good as oem.
