Engine & Performance
Old 07-22-2011, 03:04 PM   #1
Vic328CSi
My Ride: depends on the mood
WTB: 3.15, 3.23 or 3.38 diff
Lower miles preferred. PM offers. Thanks!
e46 328Ci 9psi SC
Vic328CSi is offline   Reply With Quote
Old 07-22-2011, 07:06 PM   #2
Steven747
My Ride: 05 330ci
i will have a 2.93 on tuesday
Old 07-22-2011, 07:42 PM   #3
Vic328CSi
Sorry, already have a 2.93 in my 328Ci 5spd, looking to swap it out.
e46 328Ci 9psi SC
Old 07-22-2011, 08:12 PM   #4
jacobs323i
My Ride: blown 323i
i have a diff from a e46 323i with about 70,000 on it i will let it go cheap!
jacobs323i is offline   Reply With Quote
Old 07-22-2011, 08:29 PM   #5
Steven747
My Ride: 05 330ci
3.46 ftmfw. im getting a 3.46 on tuesday put on and cant wait for the results
Old 07-22-2011, 08:30 PM   #6
Steven747
My Ride: 05 330ci
tede46ci has a 3.15 out of a 325 i believe.. pm him
Old 07-22-2011, 08:52 PM   #7
Vic328CSi
Is it a 5spd or Auto? If its a 3.46 I definitely cant use it, if its a 3.07 I might be interested. Could you PM me your price?
thanks, i sent him a PM.
e46 328Ci 9psi SC
Old 07-22-2011, 09:05 PM   #8
Steven747
My Ride: 05 330ci
why cant you use a 3.46???
Old 07-22-2011, 09:16 PM   #9
Vic328CSi
Not that I cant go 3.46. Cruising rpms too high for my use, top speed is affected too much and would have to shift to second pretty quick.
e46 328Ci 9psi SC
Old 07-22-2011, 09:17 PM   #10
Steven747
My Ride: 05 330ci
assuming you have a 5spd? because 6spd crusing rpm's and mpg are bearely noticable
Old 07-22-2011, 09:57 PM   #11
Vic328CSi
yes, a 5spd 328Ci with forced induction
e46 328Ci 9psi SC
Old 07-22-2011, 10:06 PM   #12
Steven747
My Ride: 05 330ci
Originally Posted by Vic328CSi View Post
yes, a 5spd 328Ci with forced injection
what is forced injection? sounds cool
Old 07-22-2011, 11:06 PM   #13
Vic328CSi
I mean forced induction
I was thinking about my water/meth injection system when I was writing that.
e46 328Ci 9psi SC
Old 07-23-2011, 12:30 AM   #14
Steven747
My Ride: 05 330ci
so how does rms stages go? stage 1 just bolt on suercharger? at what psi? stage 2 with intercooler and 2.5 with meth or teach me about rms.. and also what kinda numbers does it put down along with what stage do you have?
Old 07-23-2011, 12:42 AM   #15
jacobs323i
My Ride: blown 323i
it is a 3.46 i run a custom turbo it is perfect for f/i, also is a 5 spd i would do $350 plus shipping
Old 07-23-2011, 12:52 AM   #16
Steven747
My Ride: 05 330ci
ehh sorry to break it to you but i wanna protect op. i just got my 3.46 shipped greyhound for 225 shipped. 3.46 are the most common and yes they are heavy. anything above 275 or 300 plus shipping puts you into the rarer 3.38,3.15,3.23 range
fyi
Old 07-23-2011, 01:10 AM   #17
jacobs323i
My Ride: blown 323i
fyi
okay 200 shipped
Old 07-23-2011, 01:26 AM   #18
Vic328CSi
Intially had an ESS 7psi kit, which gave me hell, ripped it out. Now has an ESS modified ecu with all the emission stuff removed, larger injectors, then everything else is a RMS done by Osh. v2 vortech blower@9psi, piggy back fuel controller. Pretty much the highest boost on an otherwise stock motor. It did 293rwhp on 100 octane abour a year ago. Its almost maintenance free, except I do more frequent oil changes. No need for an intercooler really, its more a daily driver than a track car. I dont expect heatsoak to be that much an issue with my street use.
The water/meth injection system(coolingmist) is my own addition about 2 months ago, solved the early detonation/hesitation I would get on WOT at high boost. Amazing difference, should have done it much sooner.
Now I need some better gearing.
e46 328Ci 9psi SC
Old 07-23-2011, 01:30 AM   #19
Steven747
My Ride: 05 330ci
what went wrong with the ess kit? and im sure a intercooler would help you run higher boost with more safety. and what brand meth are you using? do you have "rms headers"?
Old 07-23-2011, 01:43 AM   #20
Vic328CSi
Just running 50/50 methanol (gas line antifreeze) and distilled water. no headers. ess kit had constant hose slipping, blower oil leaks/bearing noise like you wouldnt believe, slipping belt issues. left a nice oil puddle everywhere, made a mess of my undercarriage. long story, couldnt be resolved. not one oil leak since i had it changed.
e46 328Ci 9psi SC
