Old 07-22-2011, 04:15 PM   #1
wroberts
My Ride: 323Ci
How to test a thermostat?
My 2000 323Ci has been occasionally overheating and since I have recently replaced the water pump and thoroughly bled the air out of the cooling system according to e46fanatics standards, I believe that the thermostat on my car may be stuck shut. I was wondering how I would go about testing the thermostat to make sure that it is faulty before replacing it. So if anyone has a method of testing, please tell. Thanks
wroberts is offline   Reply With Quote
Old 07-22-2011, 04:26 PM   #2
jgold47
My Ride: 2004 X5 3.0
it usually sticks open....that said, there is probably a way to test. Its a realatively cheap replacement, and not a terrible DIY. I did it in about an hour in 15deg weather. Probably worth replacing.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 07-22-2011, 04:26 PM   #3
RossGuy
My Ride: 98 Volvo S70 T5
I believe you can put it in a pot of water and see if it opens when the water reaches that temp.
Mods- ARD "Green" tune, FMIC, Turboback 3" exhaust, MSD ignition, Snabb intake, IPD CAI, ARD TCV, Forge CBV, SAS delete, Rear o2 delete, Evap delete, some other goodies.
Originally Posted by NFRs2000nyc View Post
Shut up and drink your snow from your plastic cup you hungry homeless homosexual.
RossGuy is offline   Reply With Quote
Old 07-22-2011, 04:28 PM   #4
RockLee
My Ride: 99 328i. ZSP, ZPP,
Send a message via Yahoo to RockLee Send a message via Skype™ to RockLee
This is an electric thermostat. So don't boil the connectors.
1999 328i Sport Package, Premium Package, 5 speed, Alpine white.
RockLee is offline   Reply With Quote
Old 07-22-2011, 04:30 PM   #5
RossGuy
My bad. Still new to the BMW world so was going off old knowledge.
Old 07-22-2011, 05:00 PM   #6
LivesNearCostco
My Ride: 2003 ZHP 6MT
I thought about boiling mine since by the time I suspected it was stuck shut, the electrical heater circuit had already fried itself. Since the thermostat was on the car, I tried this instead:
  1. Bleed cooling system and remove main fan (Auto) or only fan (MT)
  2. For bonus points, unlock hidden OBC menu to watch coolant temp on instrument cluster
  3. Start car and drive around until temp gauge is in middle
  4. When temp gauge climbs beyond middle turn heater to 91F, fan high, vent dial to 3 red dots to prevent overheating since the heater core acts like a mini radiator. Do NOT let gauge go into the red zone.
  5. Park car, feel upper and lower radiator hoses plus radiator. WARNING, may be hot enough to burn you
  6. Replace thermostat if needed. Rebleed if you replace thermostat.
  7. Repeat test to make sure new thermostat opens when car is at operating temp
  8. Put fan back on.
If upper hose is hot while lower hose and radiator are cold, your thermostat is probably stuck closed. But since it's supposed to be closed when the car is cold, you have to let the car warm up first before checking the hose temps.
LivesNearCostco is offline   Reply With Quote
Old 07-22-2011, 05:43 PM   #7
ZHPRegistry
Past Site Sponsor
My Ride: was a bit tiresome
Can you tell us specific conditions under which it overheats? Does it ever happen when you are traveling over 40MPH? Some of these signs may help you to identify the problem without needing to take the thermostat off. In my opinion if you are going to test the stat by removing, might as well just get a new one (depending on how old it is).
ZHPRegistry is offline   Reply With Quote
Old 07-22-2011, 05:53 PM   #8
wroberts
My Ride: 323Ci
Currently it's pretty hot in Ga. My car only overheats when stopped, and when I start driving again it will cool down. It doesn't overheat every time I stop, but sometimes. I generally just blast the heat in my car and the engine cools down.
Old 07-22-2011, 05:56 PM   #9
ZHPRegistry
Past Site Sponsor
It's not your thermostat. It's your fan clutch getting weak. With the stat stuck closed the temp will rise even if you are moving fast.
Old 07-22-2011, 07:41 PM   #10
LivesNearCostco
Agree with ZHPRegistry. Ignore my thermostat test plan. If you have an AT, it's your fan clutch. If you have MT, it's either temp sensor in lower radiator hose or relay for electric fan.
Old 07-22-2011, 09:35 PM   #11
iansanderson
My Ride: 2001 330CiC
sounds like an air movement problem. are the fans working?
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
eGay = eBay
iansanderson is offline   Reply With Quote
Old 08-08-2011, 06:54 AM   #12
denziano
My Ride: 325i
fan clutch problem
hey guys, i need u'r expert opinions. Are these fan clutches reliable? What causes the fan clutch to burn out? This is my second one it lasted 80k, is this normal?
THX
denziano is offline   Reply With Quote
