Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 4.83 average. Display Modes
Old 07-26-2011, 04:58 PM   #1
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
DYNO: M54B30 intake manifold swap
Here is my pre dyno result (baseline) from today. I am going to do the intake manifold swap and then get it dyno again later this week at the same shop.
Tips on Dyno:
1) Make sure the car is fully adapted to your modifications before you go get tested or reset your adaptation. I reseted my adaptation and drove about 75miles to the Dyno shop.
2) Make sure the dyno shop you use has adequate fans and ventilation.
3) Measure air/fuel ratios from the right tailpipe.
4) Disable the traction control system.
5) For automatic transmissions: Shift the car in to 4th gear in sport mode, bring the RPMs up to around 1800-2200, and then floor the car to right before the kick down switch. If you floor it all the way, the car will downshift and screw up your run. If you are afraid of activating the kick down switch then disable it. I disconnected mine
My car:
M52TUB25, Exhaust, Intake, Shark, UDP, Headers
Atomospheric Condition: Hotter than freakin Kenya! 105-107 degree F and Humidity at 11-12%
I did four runs. We only graph 3 out of 4 runs because the first run was just a practice. I was in the driver seat and wanted a test run to practice getting the car in 4th gear, disabling DSC, and not trying to activate the kick down switch.
Best run is #4 at 168.96HP and 161.07 Ft/lbs (106.73F and 11% humidity. SAE correction 1.04. SAE Smoothing 3)
Alright on to the Dyno. I am concern about the dips at ~4.2K and ~6.3K
I will post another DYNO to see if I gain/loose anything from the intake manifold swap.
Old 07-26-2011, 05:07 PM   #2
Iceman00
Banned User
My Ride: E90 6MT
Dips are normal, and the first is due to the DISA valve in the manifold, the second more than likely do to manifold resonance. Every M52TU dyno has them. Great job on the dyno, can't wait to see how the M54 manifold performs.
Old 07-26-2011, 05:26 PM   #3
flashmeow
Banned User
Thanks. If I get some gain on my intake manifold then I am going to buy you a beer. If you don't drink then I am going to buy you a pet kitten.
Old 07-26-2011, 05:48 PM   #4
SweTurbo
Big Pimpin'
My Ride: 323i -98
Subscribed !
Old 07-26-2011, 05:53 PM   #5
azshorty
My Ride: Hellrot 323CI
is this a 323?
azshorty is offline   Reply With Quote
Old 07-26-2011, 06:06 PM   #6
Hornung418
My Ride: '04 MB ZHP
Originally Posted by azshorty View Post
is this a 323?
Yup.
And despite all the mods it's lacking a lot of torque...why am I making 40 more lb/ft than OP, if I only have .3 litres difference in displacement?? Hopefully the new B30 manifold helps you there.
EDIT: Automatic transmission...
Hornung418 is offline   Reply With Quote
Old 07-26-2011, 07:21 PM   #7
Iceman00
Banned User
My Ride: E90 6MT
Love cats, but I'll take a blue moon and don't forget to update your post in they dyno thread.
Old 07-27-2011, 05:37 PM   #8
flashmeow
Banned User
UPDATE: Half way done. Pulled out my intake manifold but can't put anything back together until I clean out the M54B30 intake manifold. it is caked with carbon deposit.
Pulled out my intake manifold today. Took me about 4 hours. Went pretty smoothly except that I dropped a few fasterns and now I have to look for them.
Some observation: High Quality Gas (I always used Chevron w/ Techron and/or Shell w/ Nitrogen) makes a difference in cleaning your intake/fuel injection system. The M54B30 intake manifold was CAKED with heavy deposit of carbon by the intake and fuel injector ports. When I pulled out my old intake manifold (M52TU) the areas I mentioned above was clean. There was no trace of carbon deposit. the only residue were oil/fuel. I am rather surprised because I have over 120,000 miles on my car.
1st Pix: M54B30 intake manifold with all the o-rings/gasket and 330 DISA
2nd Pix: My engine bay
3rd Pix: Remove strut bar, cabin filter, CAI
4th Pix: remove MAF, DISA, ICV
5th Pix: remove Throttle Body
6th Pix: remove fuel injectors
7th Pix: fuel injectors
8th Pix: difference between 330i and 323i DISA
9th pix: engine bay without intake manifold
ID:	410781   Click image for larger version
ID:	410782   Click image for larger version
ID:	410783   Click image for larger version
ID:	410785   Click image for larger version
ID:	410786   Click image for larger version
ID:	410787   Click image for larger version
Old 07-27-2011, 05:40 PM   #9
flashmeow
Banned User
1st Pix: old intake manifold
2nd Pix: M54B30 intake manifold with carbon deposit spilling out after spraying with brake cleaner
3rd Pix: my M52TUB2 intake manifold. no trace of carbon build up.
I am so glad I paid extra for Chevron/Shell
Need to go to Autozone and buy more cans of brake cleaner. Tomorrow I will put everything together.
ID:	410790   Click image for larger version
ID:	410791   Click image for larger version
Old 07-27-2011, 09:55 PM   #10
flashmeow
Banned User
more nastiness
Uploaded with ImageShack.us
Old 07-27-2011, 10:23 PM   #11
Steven747
My Ride: 05 330ci
if the weather was 70 degrees im sure you would picked up around 10 hp or what not. 107 is deadly sounding
Old 07-27-2011, 10:49 PM   #12
Iceman00
Banned User
My Ride: E90 6MT
I find you working on your car strangely attractive.
Call me.
Old 07-27-2011, 10:53 PM   #13
new//M3fan
My Ride: 77' 924 87' E30
^^^ lol
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 07-28-2011, 01:38 AM   #14
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
im in
Old 07-28-2011, 11:54 AM   #15
flashmeow
Banned User
Mini update: grind down the TB. test fitted and everything is good to go. just have to transfer a few things from my old intake manifold to the new one and I should be good to go.
Old 07-28-2011, 12:24 PM   #16
SweTurbo
Big Pimpin'
My Ride: 323i -98
I cant believe you did it with a dremel , i just got my big 'ol grinder and chopped it off ^^
Old 07-28-2011, 12:37 PM   #17
Rubenk
My Ride: M35A2
I had a local machine shop hot tank an intake manifold for me and it looked like factory new! Only cost a couple bucks and a few hours, so if it isnt too late you might consider that!
Rubenk is offline   Reply With Quote
Old 07-28-2011, 12:38 PM   #18
flashmeow
Banned User
I am not good with power tools so anything bigger than a dremel will either mess up my manicure or get me seriously hurt
Old 07-28-2011, 12:39 PM   #19
new//M3fan
Old 07-28-2011, 12:43 PM   #20
flashmeow
Banned User
that is a good idea. Let me look into that. How would i look for machine shop in the yellow page? is it listed under auto repair?
The good news is I think I cleaned out the majority of the carbon build up after spraying about 7 cans of brake cleaner and scrubbing it down with my husband toothbrush and running my water hose through the manifold. the only thing remaining is oil dried oil residue (ie..similiar to your valve cover) but I am okay with that.
