///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 07-27-2011, 04:59 PM   #1
dmw16
My Ride: 2005 M3 ZCP
Constant Pressure Valve - $739?!?!?!
I bought a "new" 05 M3 from CarMax 2 weeks ago and took the car to a well recommended and highly regarded indy shop for a valve adjustment and alignment.
I got a call from the shop today that they found 2 things:
1. Rear trailing arm bushings are shot too badly to do the alignment. Frustrating but not shocking.
2. Constant Pressure Valve is leaking or seeping. I'm leaning towards seeping as I've seen no oil on the garage floor or anything.
The RTAB were quoted at $540 and the constant pressure valve at $739. I called carmax and read them the riot act (although shame on me for not doing a PPI before my return window closed).
But I went online and the RTAB swap seems straight forward. A pain and I get why it would be $500 @ a shop but doable for an at home DIY.
Then I went online to look at the constant pressure valve. It sounds like a pain in the butt, but again seems doable and the part is only $40. Am I missing something about the job? Why did they quote me so much? Does the 'book' time include pulling the header?
dmw16 is offline   Reply With Quote
Old 07-27-2011, 05:16 PM   #2
30seconds
My Ride: M3 vert
RTAB needs a special tool and is a pain.
30seconds is offline   Reply With Quote
Old 07-27-2011, 05:18 PM   #3
SledgeHammer!
My Ride: 2005 E46 M3
Your indy shop is ripping you off. $739 is DEALER price for the CPV value. Indy shop pricing is ~$300 to $400. The valve itself is like $50. The rest is all labor. Your indy shop probably quoted you the "remove the header" price... you can swap the CPV valve without removing the header.
SledgeHammer! is offline   Reply With Quote
Old 07-27-2011, 05:20 PM   #4
dmw16
I don't really want to fight with the indy shop over it and really don't feel like screwing around with carmax.
I am leaning towards getting my car and doing the work myself. I know the RTAB job is a bit of a pain, but it might be worth it to have good aftermarket bushings and to not have to screw around with carmax. Because if I take it in and they say they aren't going to fix it I'm going to go into orbit.
Old 07-27-2011, 05:39 PM   #5
daschae
My Ride: M3/M5/F350/Denali
Are you sure the TOTAL isnt the $700? The RTAB are a PITA and worth paying to have done, the CPV however is easy. Part is $40, shouldnt take ANYONE more than 1.5 hours. Just call the INDY and tell him if he can do it all for $729 you will do it.
daschae is offline   Reply With Quote
Old 07-27-2011, 05:43 PM   #6
dmw16
He gave me a seperate quote for each job so I'm pretty sure he didn't mean total. Beyond that I'm thinking I should just do it myself to 1) learn the car 2) have satisfaction of a job well done and 3) not kill anyone at carmax.
Old 07-27-2011, 05:48 PM   #7
daschae
Id consider having him do the RTAB for that price..I had my first set done at the dealer and with an alignment paid about $800. The CPV is easy enough, on my first car I replaced the valve, on my current M3 I just took the o-ring off the "old" cpv and took it to the auto parts store to match up the o ring, got one a little smaller and 5k miles later its working great, o-ring was .32
Old 07-27-2011, 06:06 PM   #8
dmw16
Well I'd have to have carmax due it and only with OEM parts. I'd rather just install the rogue engineering ones and be done with it. Otherwise I'm going to be doing it again sometime.
Old 07-27-2011, 06:21 PM   #9
costac
My Ride: 03 m3
ask them for a price if the same parts were on a honda. i had my valve replaced by turner motorsports for $140 total and the rtabs were $440 approx. turner is a well known shop in my area.
costac is offline   Reply With Quote
Old 07-27-2011, 06:23 PM   #10
dmw16
I'm sure the ///M badge raises the price. For $250 out of pocket I bought new (non-OEM) RTAB's, the tool to press them out, and a new CPV.
I'll just do it myself and avoid the aggravation.
Old 07-27-2011, 07:08 PM   #11
cityjohn
My Ride: 2001 M3
That's the way to go. I hate taking my car to a shop (and fortunate to have access to tools and have the time to do the work). Plus if you ever decide you want someone else to do it later you know exactly what the job involves.
cityjohn is offline   Reply With Quote
Old 07-27-2011, 07:31 PM   #12
mdsonicTT
My Ride: 3rd gear
The shop is charging too much -- RTABs should take no longer than an hour. I've had them swapped in under an hour with standard tools. Find the hourly rate and book time for swapping components (RTABS should be around an hour or less.)
mdsonicTT is offline   Reply With Quote
Old 07-27-2011, 10:36 PM   #13
RAFF112
My Ride: 325ci M3 cbr 600rr
Lmfao impressive charged me like $50 to replace this.
Sent from my PC36100 using Bimmer App
VCSL Front 18/13 Spacers Full Borla V2 K&N drop-in w/custom tube LED Interior air horn BMW performance shift Knob Seibon Hood LED DRL Dynavin Depo corners RE rear camber arms and Vogtland Springs.
Originally Posted by hayabusa55 View Post
I used to think love exists. Turns out it's a manifestation of insecurities and boredom.
RAFF112 is offline   Reply With Quote
Old 07-28-2011, 03:54 PM   #14
dillard
My Ride: 2004 M3 Cabrio
CPV is a pain without a lift but doable. Search DIYs for tips.
Proud owner of '04 M3 Convertible:
dillard is offline   Reply With Quote
Old 07-28-2011, 04:10 PM   #15
AlbertM3
My Ride: 2004 M3
CarMax is a rip off
AlbertM3 is offline   Reply With Quote
Old 01-22-2013, 08:19 PM   #16
jaramill
My Ride: White 2005 BMW M3
Same here as I just responded to another thread What is the "euro valve"? as I hadn't heard of the "Euro valve" (aka the CPV - Constant Pressure Valve).
jaramill is offline   Reply With Quote
Old 01-24-2013, 10:41 PM   #17
fu98
My Ride: 2002 m3 6mt
you can get this tool , use it, then sell it back or rent it to people on the forum. the pain will be no worse than jacking the car up!
http://www.ebay.com/itm/MIS-BMW-E36-...70948379574%26
fu98 is offline   Reply With Quote
Old 02-05-2013, 04:37 PM   #18
NoMoreIdeas
My Ride: 01 M3
I know this is an old post, but RTABS are like $18 each, and once I got the hang of it, it took me about 45 mins / side. The CPV valve just needs the oring replaced, which is about $3 shipped, and took me about 45 mins to replace as well. I borrowed the RTAB tool from a local enthusiast, and made the CPV tool from by bench grinder.
In short, all this can easily be done for less than $60 and about 3 hours of your time.
NoMoreIdeas is offline   Reply With Quote
Old 05-09-2015, 05:19 PM   #19
iansevilla
My Ride: 2004 M3 Coupe
I only got charge $130 for replacing FTABS and RTABS. Parts was mine and rented the tool here on the forum. Spent $50 for the tool rent coz we damaged and broke one of the long studs. FTABS are more pricey than the rears.
iansevilla is offline   Reply With Quote
Old 05-09-2015, 08:31 PM   #20
m3e46freak
My Ride: m Twee lol
... WOW, sounds like a particular company...around DC that charges outrageous prices.
CPV takes less than one hour. The RTABS will take under three...
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
