Dynavin NAV not booting up? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BAVSOUND
Old 07-28-2011, 08:51 PM   #1
pilot_alex
My Ride: 2014 435I Msport
Send a message via MSN to pilot_alex
My unit works but when i hit NAV it wont go past the blue screen just stuck at starting.... all other functions work on the unit.
pilot_alex is offline   Reply With Quote
Old 07-29-2011, 01:48 AM   #2
TitanSilverE46
My Ride: 2001 318i & 325i
You do have an SD plugged in with the iGo 8 or iGo Primo program don't you?
TitanSilverE46 is offline   Reply With Quote
Old 07-30-2011, 01:51 PM   #3
pilot_alex
Yes the sd is plugged in. I have igo8. Should I just Download primo and new maps and try that? It just randomly stopped working. Just goes to starting that's about it. See attached pic.
Old 07-30-2011, 02:09 PM   #4
bamfirefox
My Ride: E46 330ci
Similar problem with mine. It brings up the loading screen for the navi unit, then just freezes, crashes and restarts halp
bamfirefox is offline   Reply With Quote
Old 07-30-2011, 03:51 PM   #5
petrut
My Ride: bmw e46
1. Gps board dead, need another
2. Gps board wince system corrupted, you need to reflash with gps firmware
petrut is offline   Reply With Quote
Old 07-30-2011, 06:02 PM   #6
pilot_alex
Hmm mine just won't go past starting. How do you flash the software?
Old 08-26-2011, 12:36 AM   #7
omhl
My Ride: E46 M3 6MT
Send a message via AIM to omhl
or you could just retransfer the files...
omhl is offline   Reply With Quote
Old 08-26-2011, 11:25 AM   #8
lawdog48825
My Ride: M3 Vert
I have the same problem intermittently. Music side works no problem. Occasionally when I get in the car, the nav just wont fire up. I can typically reboot and it works fine again. Its not a dead board, but it is a little buggy. Anyone else have the same problem?
05 M3 Vert - 6MT - Jet Black
lawdog48825 is offline   Reply With Quote
Old 08-26-2011, 02:46 PM   #9
robin325ci
My Ride: Helrot 325Ci
Have you guys tried using a different SD card?
robin325ci is offline   Reply With Quote
Old 08-26-2011, 03:55 PM   #10
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
yeah, thats not typical.....have you tried this ^^^^^
jeffb325@NavigationSolutions is online now   Reply With Quote
Old 01-02-2012, 01:35 PM   #11
jorge_dohc
My Ride: M3
Did anybody else figured out the solution?
I'm having this issue.
So far, this is what I've noticed:
1) It only happens when I have not used the car for 2-3 days or more.
2) If I hit the NAVI button immediately after starting the car, then I get stuck in the navi boot screen. Only way out is to wait for at least 15 minutes and switch ignition off and back on, then I get an error message in CHINESE saying something like "last time system did not start properly and do you want to erase all data Y/N" (POI's, saved addresses, iGO configuration, etc). It is not necessary to erase anything, just hit NO and unit restarts correctly. Also tried hitting YES and it erases all configuration and restarts properly.
3) If I wait same 15 or more minutes before hitting NAVI, then I go directly into the chinese error message, hit NO and then it restarts correctly (No need to switch ignition off).
- I'm using latest version of dynavin Windows CE.
- Navigation is iGo primo.
I did not try using another SD card. I copied all contents of the supplied 2GB SD card into an 8GB SD card which I'm using. I will also try with the original supplied SD card and let you guys know.
Thank you!
jorge_dohc is offline   Reply With Quote
Old 01-23-2012, 04:24 PM   #12
jorge_dohc
My Ride: M3
Thank you!
Just in case some one runs into this post.
I went back to the supplied 2GB SD card and stopped having problems.
Therefore, using a different SD card causes issues for sure.
Old 01-26-2012, 07:57 PM   #13
rurena
My Ride: United States
it might not like cards larger than 4GB.
rurena is offline   Reply With Quote
Old 11-13-2012, 12:03 PM   #14
hbnagji
My Ride: 330ci
Hello guys,
I own a D99 WINCE - e46 unit which I bought and installed in January this year. Everything was working fine until a couple of days ago when I noticed my navigation stop working. I.e. every time I hit the NAV button or try and enter the navigation module from the touch interface, the screen just goes blank. I tried resetting the system several times but that didn't help . I've also noticed that the annoying PDC screen (when in reverse) started showing the obstruction lines as if my car has the sensors installed when it doesnt. I dont know whats going on, has anyone come across these issues before? has something in the software gone corrupt?? GPS board fried?
I've been using SD cards with upto 8gig memory for navigation and everything worked fine. I tried using the 4gig SD card with the original navigation software that came with the unit but didn't work.
Any help is much appreciated.
H
hbnagji is offline   Reply With Quote
Old 11-13-2012, 02:28 PM   #15
J&T Distributing
My Ride: BMW
answered on the other thread
