51A inspection - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-28-2011, 09:45 PM   #1
TWEEk
My Ride: 2001 325i Sedan
Exclamation 51A inspection
Model:2001 325i manual sedan
I tried to reset the "service engine soon" and all I see is
[cODE 51A]
And the "service engine soon" remains..
This is the procedure I tried, but no luck:
"To reset the indicator:
-The car should be off
-hold down the left instrument button (the trip odometer reset)
-while holding the key, turn the ignition to position 1 (radio)
-you will see a test menu
-keep holding the button
-after maybe 10 seconds, the word "reset" will appear
-let go of the button and press again
-the indicator is reset!"
HELLROT EFFIN 325i
" Living below your means is the secret to prosperity.. "
TWEEk is offline   Reply With Quote
Old 08-02-2011, 01:35 AM   #2
TWEEk
51 views and no one knows S**t ?!
HELLROT EFFIN 325i
Old 08-02-2011, 02:02 AM   #3
j_block
My Ride: 2003 325i
There is a video on youtube...I think solidjake made it
j_block is offline   Reply With Quote
Old 08-02-2011, 07:36 AM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
The oil change and inspection indicators are not the same thing as the Service Engine Soon (SES) light. Are you referring to the service indicator message in the cluster's digital display or are you talking about the SES light? The SES can't be reset by the procedure you listed. That procedure is for resetting the oil change and inspection reminders. I use my Peake tool to reset the service intervals but my understanding is that you should expect a message such as "end SIA" when completing the above procedure. You're probably misreading "SIA" as "51A". Perhaps what you're seeing is telling you the procedure is complete and that your next service will be an inspection as opposed to an oil change.
If you have the actual SES light illuminated, then you have a problem with the car which needs to be addressed. Until the problem is fixed, the light won't go away. In order to find out what the problem is, you would need to begin by scanning the car to retrieve all diagnostic trouble codes which are stored. This can't be done via the OBC, you will need an OBDII or Peake scan tool. Better yet, just take it to a shop that knows BMWs.
Old 08-02-2011, 08:03 AM   #5
Drewfus2101
My Ride: N/A
Originally Posted by tweek View Post
-the car should be off
-hold until 'reset' shows (~5 sec)
-release button, and re-press it
-after another 5 seconds, 'reset' will begin to flash
fyi
Drewfus2101 is offline   Reply With Quote
Old 08-03-2011, 11:38 AM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Here is my vid
Old 08-07-2011, 04:21 PM   #7
a1luva21
My Ride: 325 I
Thanks for the video, I followed it step by step and it worked.
a1luva21 is offline   Reply With Quote
Old 08-16-2011, 11:23 PM   #8
TWEEk
Aww poop yeah the "service engine soon" light is on
HELLROT EFFIN 325i
Old 04-19-2017, 07:49 PM   #9
Volstang
My Ride: e46 330i smg
Does this work if you want to reset at 7500k intervals?
Sent from my SM-T230NU using E46Fanatics mobile app
Volstang is offline   Reply With Quote
