Old 07-30-2011, 02:01 PM   #1
rrgcsfb
My Ride: 2002 330Cic
Starting DIY to fix throttle body engine harness
Hi,
I'm looking for the throttle body harness connector (X6390 EDK) off the main engine harness. This is the connection that is prone to corrosion as described here: http://www.ge39.com/files/EDK.pdf
I'm investigating the feasibility of repairing the bad connection vs replacing the entire harness, and would like to get one to experiment with. My car is a 2002 330Ci.
If someone has a wrecked car or old harness they can cut this connector off of and send me, I will photograph, document and publish the test and repair procedure.
I'll gladly pay a nominal fee for this connector, with the leads as long as possible.
Please hit me up if you can assist.
Thank you,
RRG
rrgcsfb is offline   Reply With Quote
