Old 08-01-2011, 12:45 PM   #1
EXNoodle
My Ride: 330CI
Send a message via AIM to EXNoodle
Start-up idle issues
Did a lot of searching and could not find a fix for my idle issue.
It only occurs at start-up only, but randomly, regardless if the engine is warm or not.
At startup, this is what happens:
-Engine will not start
-Push on the gas while turning the key & engine will startup, but idle rough feeling like its running on half the cylinders. A srong smell of gas comes out of the tial pipe as well.
-Push on the gas again for a second, the engine reves up to 1500 rpm's and the idle corrects itself and runs smooth with no further issues.
I am thinking it is not a lack of gas, or spark, rather an issue of air at start-up. I have a hunch its the ICV or Throttle position sensor on the throttle body.
I have already done my Vanos, CCV upgrade, fuel filter, spark plugs, cleaned my MAF, DISA & ICV. I have a 117K on the car.
Anyone have any ideas on how to trouble shoot to determine what is causing the porblem?
Thanks you all in advance for your input!
Gray 2004 330CI ZHP
EXNoodle is offline   Reply With Quote
Old 08-01-2011, 01:15 PM   #2
Zchild
My Ride: 2000 BMW 3XXi ZSP
Just a suggestion but it sounds as if one of you vacuum lines from your secondary air pump has a vacuum leak or is crimped. Just my two and a half cents worth...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 08-01-2011, 02:41 PM   #3
EXNoodle
My Ride: 330CI
Thank you Zchild. I will take a look at that tonight and double check.
Gray 2004 330CI ZHP
Old 08-01-2011, 03:18 PM   #4
EXNoodle
My Ride: 330CI
any other ideas?
Gray 2004 330CI ZHP
Old 08-01-2011, 03:23 PM   #5
Drewfus2101
My Ride: N/A
Is the CEL on? Does it do it only on initial startup, or will it act up when you're idleing at a light?
If it was your ICV, it would probably act up all the time, and not clear up after a minute or two. That makes me think it's a sensor problem. If you can get it scanned, it might show if one of the sensors is out of it's normal parameters.
Drewfus2101 is offline   Reply With Quote
Old 08-01-2011, 04:11 PM   #6
EXNoodle
My Ride: 330CI
The CEL have never turned on, even when the engine idles rough at start-up.
It only occurs at start up. Never at a light.
I understand your logic, that it could be a sensor. Throttle position sensor maybe?
By scan, do you mean with my Peake Tool or another tool or maybe at the dealership.
Thank you for your input Drewfus2101.
Gray 2004 330CI ZHP
Old 08-08-2011, 12:54 PM   #7
alpine325coupe
My Ride: 2004 M3 SG/IR
Not sure if this was said, but did you check your intake boots for cracks? And cleaning your MAF will only help if it functions properly. Once the MAF is bad it needs to be replaced. I always start with the cheapest things first, so check intake boots before anything.
2004 Silver Grey / Imola Red - 146k Daily Driver
ENGINE: Scoop, Filter, Elbow, Pulleys, Tune, fan delete+SAP delete
EXHAUST: Headers, Rasp sec. 1, res. x-pipe, TopSpeed muffler
SUSPENSION: BC, subframe reinforcement
WHEELS/TIRES: Hamann PG1, 19x9.5 +25, 19x10.5 +25
DRIVETRAIN: 4.10 gear ratio
LIGHTING: Orion V2, 3000k fogs
INTERIOR: Recaro SPG reps, Cobywheel, CF trim, Dynavin clone, Stealthboxes
alpine325coupe is offline   Reply With Quote
Old 11-14-2012, 08:52 AM   #8
EXNoodle
My Ride: 330CI
Finally solved.... http://forum.e46fanatics.com/showthr...600&highlight=
Gray 2004 330CI ZHP
