Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 11-08-2011, 02:03 AM   #41
patdown
My Ride: 2005 BMW 330Ci
Is the purpose of the return lines and the distribution block just to return the air to the intake for emission control?
Would this M5 OS work just as well if I retained the distribution block and just ran some hose to it instead of using the air filter?
Pos/Neg for either method?
Pat
2005 330Ci ZHP 6MT
AA Tune, domestically engineered CAI w/aFe Pro S, UUC TSE3,
Cooling Sys ovhl with Stewart WP, BMW M3 Front Strut Brace,
Koni FSD struts/shocks with original springs,
Cryo-Stop Rotors, Akebono Euro Ceramic pads, SS Brake/Clutch lines, CDV Delete,
Mason Engineering clutch pedal, Umnitza Predator Orion AE's, smoked corners and sides,
VMR V710 18" Staggered w/Hankook Ventus V12 235's/FR and 265's/RR
patdown is offline   Reply With Quote
Old 11-08-2011, 04:53 AM   #42
muly
My Ride: 330 sport vert
Originally Posted by markgbe View Post
sorry for not replying. The part # i used was 11151406788. You can use 11151406789 but the oil return hole on it will be pointing away from the dipstick tube if mounted the way i did it, so best to use 11151406788.
Big Thanks
muly is offline   Reply With Quote
Old 11-08-2011, 07:19 AM   #43
markgbe
My Ride: 2002 BMW 330ci
Yeah purely for emissions. I was going to do it the way you're thinking until i found this thread. I thought it was nice to get rid of all the extra hoses and stuff.
markgbe is offline   Reply With Quote
Old 11-08-2011, 10:47 AM   #44
Dan330Ci~
My Ride: 330Ci Clubsport
The distribution block does return the air to the intake but if you connect the M5 oil seperator (or any catch can) directly to it you will have uncontrolled vacuum on your crankcase which is effectivaly vacuum leak, the function of the diaphragm in the stock CCV is to control this vacuum and when my stock CCV was bust I would get a huge vac leak by removing the oil filler.
On the M5 the seperator goes BEFORE the throttle bodies and hence does not pull vacuum. If you want to route the air from the seperator back to the intake you wil have to create a hole in say the airbox (post filter of course). But remember that the M5 seperator is not 100% effective and you will still draw oil-vapours into the intake. You will be gumming up your whole intake tract, where as with the distribution block you 'only' gum up the intake manifold itself (due to resonance charging etc.)
'04 330Ci Clubsport | Estoril Blue | 6MT | Black Leather/Silver Cube
Turner Motorsport | Ground Control | Stett Performance | Moroso | Powerflex | Meyle HD | Goodridge
Dan330Ci~ is offline   Reply With Quote
Old 11-08-2011, 03:46 PM   #45
patdown
Dan, my CCV does not have a vacuum line going to it, it has a cap. I don't know if our (US) CCV works different than the European one.
Pat
2005 330Ci ZHP 6MT
Old 11-08-2011, 05:08 PM   #46
Dan330Ci~
My CCV was the same, where there 'should' be a vacuum line there was a cap. However there is still vacuum going through the CCV, coming from the intake manifold via the distribution block.
Old 11-12-2011, 11:45 AM   #47
darksideracer69
My Ride: 01 325ci
If any one is interested in doing this, i have a moroso catch can and mount that i would sell for 40 shipped.
Sent from my SGH-T959V using Bimmer
ID:	424978   Click image for larger version
IMAG02051
Old 01-22-2012, 08:49 PM   #48
MatRacer
My Ride: 325xiT and E30S50
I updated my oil separator wit hthe clod climate version and its still freeze with cold weather. I'm looking forward to this mod! Waht are the long term effect of running the crankcase with no vacuum? Can it bring some failure?!?
I put 800+$ in clod climate OS (did it myself), oil flushes wit hoil cleaning stuff and +++ and it still freeze. Its time to remove that shitty system. BMW has a tendency do do simple things complicate...
MatRacer is offline   Reply With Quote
Old 01-23-2012, 01:05 PM   #49
MatRacer
Doing it on a M54 and the E39 M5 OS? It could get the throttle a bit dirty... but how much? Its done in a lot of other cars, including M5. Can it be that bad? It would have to be connected after the MAF, since you dont want to gum it.
You would keep the vacuum in the crankcase and this would not create a vacuum leak in the intake since you are before the throttle body. Also, you would not create any fumes and oil smell.
What do you think?!?
Old 01-23-2012, 02:09 PM   #50
Dan330Ci~
Sorry to hear about this. I am not aware of any concern with running no crankcase vacuum, excluding what newe46fan said about low tension piston rings.
Sure this would work, I think you are going to get some dirtiness in the throttle and intake manifold but probably not much more than what you get with the stock system (and that can be quite a bit). But with your method you are returning the water vapour to the sump as well, which is one of the benefits of venting to atmosphere, because when the water in the oil is heated up sufficiently it can escape freely and either condense in the tank or escape out the filter.
Old 01-23-2012, 02:24 PM   #51
MatRacer
Well I would think that the moisture that is sucked by the intake actually go of the engine with the exhaust fumes... However, I agreed that when its cold outside, the water vapour must condense in the OS (or on its way to it), and return in the sump instead of going to the intake in its vapour form. But without the OE OS, it wont create any failure (like frozen OS causing a pressurisation of the crankcase), except the fact that having water in oil is not a good thing...
to avoid the water to go back to the sump, I could use a "standard racing catch can" and instead of putting a little filter on it, run a pipe to the intake, in between the MAF and the throttle.
Old 01-23-2012, 02:38 PM   #52
Dan330Ci~
Good point, also yes you could just use a catch can in place of the M5 OS, I would just advise to use one that is internally baffled or has some form of media to catch the vapours.
The problem comes when people run that pipe back to the distibution rail on the intake manifold!
Old 02-08-2012, 09:39 AM   #53
MatRacer
Thanks.
I capped the bungs off the same way you did, with some 3/4" vacuum caps i found at my local auto parts store, with band clamps.
I'm looking for 3/4'' vacuum cap and no auto parts stores have it in here... Do someone have a North American wed site where I could find this?
Old 02-08-2012, 09:57 AM   #54
Drewfus2101
My Ride: N/A
Instead of trying to cap the holes for each individual runner with a vacuum cap, I bought some black rubber stoppers and some JB weld, and glued them in there. They stuck out some, so once they dried, I cut them off flush with the top. You would never know that I did anything just by looking. Got the black rubber stoppers at Home Depot or Lowes.
Drewfus2101 is offline   Reply With Quote
Old 02-17-2012, 12:22 AM   #55
Jason5driver
My Ride: 2001 E39 525i sport
The distribution block does return the air to the intake but if you connect the M5 oil seperator (or any catch can) directly to it you will have uncontrolled vacuum on your crankcase which is essentially a vacuum leak, the function of the diaphragm in the stock CCV is to control this vacuum and when my stock CCV was bust I would get a huge vac leak by removing the oil filler.
You need a PCV from the M5 separator to the valve cover to keep blow-by from happening.
The OEM stock CCV is an oil separator and check valve in one.
Jason5driver is offline   Reply With Quote
Old 03-20-2012, 03:30 PM   #56
pjaneiro
My Ride: 2004 330IX
Originally Posted by DangerousMind View Post
Just wait a few months and you will have oil residue all over your engine bay and an oil caked catch can filter. Also, how does your air conditioning smell?
That is Bullcrap, I have no catch can at all, i've been running withou the ccv system for almost 2 years now, I seldom have an oil smell when i am on a hill and engaging to first, i have no caked oil, the idle is smoother and my intake manifold no longer has an oily residue on it...
pjaneiro is offline   Reply With Quote
Old 03-20-2012, 03:46 PM   #57
trizzuth
My Ride: 234k, 16yr old B3AST
So i guess the real question here for us in America is: Will you still pass inspection doing something like this? Catch/Breather can says specifically it is "not legal for sale or use on pollution controlled motor vehicles."
Looks awesome though, I am amazed that you can close your hood flush with it sticking up above the washer fluid reservoir like that!
trizzuth is offline   Reply With Quote
Old 01-22-2013, 12:41 PM   #58
Andrew99328i
My Ride: 328i 99
i love this thread.
proves amounts of OEM stupidity.
Andrew99328i is offline   Reply With Quote
Old 01-22-2013, 01:00 PM   #59
markgbe
I passed inspection with this in NY state.
Old 03-06-2014, 06:51 PM   #60
18rabbit
My Ride: '02 330it
Sorry to bump, but any updates or consensus on the vented catch can?
18rabbit is offline   Reply With Quote
