Some models can't have tranny fluid changed? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 08-01-2011, 06:32 PM   #1
Kisorsosay
My Ride: 2004 325xi
I was speaking with a BMW serviceman earlier today and he had told me that there are several types of transmissions that were used in the xi's (Mine being a 2004 as well).
He said that one type, a common one, is that you're not supose to change it at all, while others can be, all depending on the tag on the bottom of the tank? Can anyone confirm and what do I need to do to determine which one I have?
Kisorsosay is offline   Reply With Quote
Old 08-01-2011, 06:41 PM   #2
Gus330vrum
My Ride: 330ci
Everyone in this forum have changed it!..!.. impossible to not change a 100k car ( all e46 have same defect )rear spring brake, cooling system overhaul, O2 sensors, tail light error, (burns it) and eventually suspension overhaul ... because u can tell the driving difference from when u got it ..... meaning... after 100k. i would not trust bmw Lifetime Tranny manual oil. after all.... i changed my 2003 325xi. tranny fluid w purple magic (hehe) feels better... about to do the next Tranny Fluid change after 30k.... Soon.... no problem yet.... feels great...!
any suggestion for my Next Tranny Oil change? ( Better then Purple magic ) ? ... and speaking of tranny... i have not done my DIFFS front-rear ones.... ( any advice on a good Diffs fluid )? redline ?... ? ...
Gus330vrum is offline   Reply With Quote
Old 08-01-2011, 07:30 PM   #3
shadow 2
My Ride: 07 328i
To answer the OP, I am unaware of any xi auto tranny that does not allow fluid change. BMW makes it hard to do but it still can be done. BTW, i am not aware of any auto tranny in 04 for the xi other than a GM.
shadow 2 is offline   Reply With Quote
Old 08-01-2011, 11:41 PM   #4
TrickTizzle
My Ride: 325i
only the super ghey ones...
Old 08-02-2011, 12:11 AM   #5
Fred The Puppy
My Ride: 330XI
2004 325XI auto is GM A5S390R. Supposedly 'Lifetime' fluid is Texaco ETL (Extended Transmission Life) 8072B, which is no longer available. Castrol All-Import ATF is compatible with all E46 transmissions; that's what I use.
http://www.castrol.com/liveassets/bp...s_ImportMV.pdf (scroll to page 2)
Some have had good luck with Redline D4, and even some have said Dexron VI is fine.
Fred The Puppy is offline   Reply With Quote
Old 08-02-2011, 03:53 AM   #6
benzedid
My Ride: 2001 BMW E46 318i
The word "Lifetime" for tranny fluid doesn't necessarily mean lifetime warranty. according the the BMW mechanics, its only the trademark that is lifetime nah seriously... thats wat they told me when i first made that face when i heard it was "lifetime". one tip: for my E36 one garage told me that the tranny fluid for BMW and Audi cannot be changed. yet, another BMW garage changed it right in front of me. don't believe just anybody.
benzedid is offline   Reply With Quote
Old 10-06-2011, 07:19 PM   #7
A3ferthee
My Ride: 2003 330Xi
Amsoil ATF good to use also.
A3ferthee is offline   Reply With Quote
Old 10-12-2011, 06:34 PM   #8
Texas325xi
My Ride: 08 328i Sport Pac
They tell you that because if everyone would diy then they would have no one to sc@w!! lol.
Texas325xi is offline   Reply With Quote
Old 10-12-2011, 06:46 PM   #9
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
"lifetime" does not mean how long you have the vehicle. it is the "lifetime" of the transmission, which could be 100k or longer depending on what the company considered the life expectancy of the transmission to be.
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 10-13-2011, 08:38 AM   #10
rafar
My Ride: e46 330xi; x5 3.0i
I've got a 2001 330xi manual and just did the tranny, transfer case, front and rear diff all with redline fluids. I researched all these forums a lot, found the sticker on the tranny (mine's yellow stating it requires MTF - 1) and finally settled on Redline D4 ATF for the tranny and x-fer case with 75-90 gear oil for the diff's after all the reading. I suppose that at the end of the day, as long as you are doing regular interval changes and using fluids with more or less the same spec, it doesn't matter which ones you use (Redline, Royal Purple, Pentosin, etc...). Oil that came out of the tranny was "ok", but the transfer case was disgusting. I have 120K on the car and it must have never been changed. I have noticed a significant improvement in noise, and smoothness of the entire driveline. I had bought my car with high-miles and didn't know how well the owner really took care of the car. So far, so good. Now if I can just sort out that XI thud (no subframe issues - going to try flushing the brake/clutch fluid next), i'll have the ultimate driving machine.
rafar is offline   Reply With Quote
Old 06-21-2015, 09:55 PM   #11
joe lochner
My Ride: 2003 bmw 325xi
Rusting rear differential drain plug gasket
I have a 2003 BMW 325XI with 61K miles. I also read that rear differential was sealed and oil was not to be changed for the lifetime of the car. That's not a good idea in northeast USA snow country. The rear differential filler plug metal gasket over the years corroded causing breaks in its seal so that oil was leaking out and the differential was barely half full. Luck I saw leaking oil and replaced oil and gasket before serious damage occurred.
joe lochner is offline   Reply With Quote
Old 06-24-2015, 11:27 AM   #12
White_Knuckles
My Ride: 2003 325xi
This is across the industry. German at least. Mercedes claims the same thing "lifetime" fluid. Yes, Merc owners in the know change out their fluids. The common thing is neither have dipsticks. Introducing that was followed by the no service needed response where dealers still maintain it is not something they will perform. The manual lists top-off brands only. Some claimed it was worry-free marketing hype to trick owners. I think it was more of an average that most "new car" type owners could easily roll up near 100K without changing fluids. Thus lifetime. For the "old car" owners, start a new life!
The proper procedure is involved and should be researched or performed by experienced shops. Mixing occurs when new fluid is added with retained T-converter fluid. Some have a couple drains to thin out the old stuff. Redline D4 is a recommended blend spec to have good results with a single dump.
