Old 08-02-2011, 05:43 PM   #1
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Hestitation finally banished
It only took 4 years. Because of the acceleration hesitation/stumble/hiccup, the car was never quite perfect even though it was quite brilliant.
The final piece in the hesitation puzzle turned out to be the pre-cat O2 sensors. With the factory 121k O2's replaced, the car drove exactly how I liked it. What always bugged me before was the unpredictable hesitation on hard take offs from stand still. It could never be reproduced on demand and often cropped up when I least expect it to. To say it drove me nuts would be an understatement.
After doing extensive research on O2 sensors recently, I took a calculated gamble and bought a new set of Bosch-same-as-OEM sensors, and it paid off. The O2's controlled the fuel air mixture during idling and idle running (such as cruising with minimal throttle). The O2 signals were not used during acceleration, except when transitioning from idle to acceleration. Old sensors became less responsive and transitioned slowly resulting in hesitations.
My long route to success was the following:
1. Replaced vanos seals and eliminated a large amount of hesitations and poor power in first gear.
2. Cleaned the ICV and straitened the connecting air hose. This ended the kangaroo hopping when rolling the car along with no throttle from cold start. Hesitation was improved somewhat.
3. Replaced factory ignition coils with noticeable heat blisters. This improved hesitation significantly.
4. Randomly threw a new set of spark plugs at the car. It was a complete waste of money and these didn't do jack for the car or the hesitation.
5. New pre-cat O2's. Hesitation all gone. Nice, and traffic light drag racing is so much more pleasant.
GoingNuts is offline   Reply With Quote
Old 08-02-2011, 06:26 PM   #2
Jmanscotch
My Ride: makes my pants tight
Mine has some hesitation as well, although not driving me nuts, I've had a hunch that it's my ignition coils.
I recall a few maintenance guides call for new O2 sensors every 100K (since that's the typical life of them), so spot on.
Nice thread GN.
-Jake
2004 325CI - 2003 3.0 Z4 - 1994 325i - 1967 1602 - 2008 328XI - 2009 135i - 2007 Jeep Wrangler - 2014 *Loading*
Jmanscotch is offline   Reply With Quote
Old 08-02-2011, 06:45 PM   #3
5ynd1cat3
My Ride: pisses off liberals
C'mon man, everyone knows that hesitation in our engines is due to using the improper oil and the improper amount. Here's how I cured my hesitation:
1.Use 2tsp of canola oil for every 1qt of motor oil.
2.Find some grassy area after a moderate to hard rain.
3.Drive vehicle through a muddy spot in said grassy area. MAKE SURE you coat the underside in a mud/grass mixture NO GREATER than 3/1.
4. DO NOT UNDER ANY CIRCUMSTANCES wash of the mud. It's there as a protectant. Doing so will surely cause your ICV to fail and possibly a spontaneous combustion of the motor itself.
5.Finally, drain canola/motor oil mixture and flush with CocaCola. The caramel color in the CocaCola will actually hone your cylinder walls to better than factory spec. Fill motor with a fresh canola/motor oil mix and enjoy happy motoring for years to come!!
5ynd1cat3 is offline   Reply With Quote
Old 08-02-2011, 07:01 PM   #4
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Road black undercoated by copper grease mixed with cat hair is a superior under car protectant than mud and grass. My formulation is heat resistant, water repellant, and rust retardant/reverse-ant. It also gives the undercar a smart blacked-out look.
Old 09-20-2011, 03:11 PM   #5
My Ride: Lexus
Maybe I'll do this next to cure my accelerating jerking/surging at low RPMs. My car does not want to make smooth transitions at low rpms. It goes from no power to full power and produces a very annoying surging/bucking. Then after that it pulls healthily and normally to redline.
Old 09-20-2011, 04:12 PM   #6
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
So what is it about an O2 sensor that causes it to fail? I don't want to know how long mine have been in there, but I can idle at 1'/sec or so it seems. I'll have to think about fixing something that isn't broken! Still, I'll have to find out what a computer can tell about the health of an 02 sensor. Interesting!
BTW, do you line the cat hairs up in a perfect grid, or just randomly? Mix in a blender or fold together?
Upcoming comedy shows: Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 03-30-2012, 05:42 PM   #7
My Ride: Lexus
I replaced my O2s and still have a surge at 2,000 RPMs. Not sure what it could be. Everythings healthy, up to date, cleaned. Vanos done. Coil boots done. Sparks done. Disa resealed and healthy. CCV done. Software updated. No codes. The surge is hard--rear ended by a minivan at 5mph hard--in first gear.
Old 03-30-2012, 05:48 PM   #8
dmax
dmax's Avatar
Well...'everything' doesn't sound healthy! lol
If it's that big of a surge, I'd randomly guess a few things:
Intake leak you don't want to admit!
MAF problem.
Maybe the throttle position sensor? I don't think I have one on mine, but believe it's a hall sensor...and if you were missing a 'hall' seems like at the next hall up, you'd have a kick. (Might be another name for it...but think there are two sensors on the pedal...you probably know it better than me)
Let the random guessing begin! (I'll say fuses and battery just to see if GN comes out of hiding to yell at me!)
dmax on Facebook
Mangofy your E46!
Old 03-30-2012, 05:54 PM   #9
NOVAbimmer
My Ride: E60M
I thought for a second that there was a new GN thread
NOVAbimmer is offline   Reply With Quote
Old 03-30-2012, 05:55 PM   #10
My Ride: Lexus
lol. No intake leak that i know of. intake boots super pure. CCV system and all plumbing replaced. no codes. I do have a 5.5+ long-term fuel trim for both cylinder banks (not sure if thats normal)
I wonder if golf-tee mod could cause this? yes its plugged with a screw and zip tie and yes i verified said screw is still in place...
Old 03-30-2012, 05:55 PM   #11
My Ride: Lexus
I bumped it to get your hopes up!
Old 03-30-2012, 05:59 PM   #12
My Ride: Lexus
And by the way, the only way to NOT experience the surge is to throttle gently until I pass 2k rpm. After that, the car is perfect. Any normal or aggressive throttle at take off results in the surge.
I'm thinking the car is actually hesitating before 2krpm and the surge is just the car accelerating how it should... though i'm not sure.
Old 03-30-2012, 06:08 PM   #13
NOVAbimmer
My Ride: E60M
You're such a tease
Old 03-30-2012, 06:11 PM   #14
My Ride: Lexus
Maybe one of our UK members can drop by and check on Nuts. I have his address. I kid you not.
Old 03-30-2012, 06:13 PM   #15
N89
My Ride: 330Ci
Should clean the ICV and throttle body while you're at it, won't hurt. What do you mean you "resealed" the DISA?
N89 is offline   Reply With Quote
Old 03-30-2012, 06:14 PM   #16
My Ride: Lexus
EVERYTHING DONE. You can EAT off of the BACK of my throttle body.. don't get me started on the ICV either.
Meaning I bought a german auto solutions seal and re-sealed my DISA. You could eat off of my DISA too. Being the OCD fanatic I am, I spent LOTS of time cleaning these parts.
Old 03-30-2012, 06:20 PM   #17
N89
My Ride: 330Ci
Doesn't matter how clean your DISA is if the valve/flap is screwed, but I'm assuming you're fine if you're as OCD as you claim lol....
Old 03-30-2012, 06:27 PM   #18
My Ride: Lexus
thats obvious. my disa is tight and retains pressure when vacuum port is blocked. nothing loose or broken
Sent from my SGH-T989 using Bimmer App
Old 11-17-2012, 01:34 PM   #19
raymoon
My Ride: Alpinweiß III
Sorry to revive an old thread, but shouldn't a faulty O2 sensor be throwing a code? I'm having the same problem, but my mechanic is saying it SHOULD be throwing a code if its working improperly. It sounds like my issue because it only happens occasionally and usually the first time I set off after starting the car (from idle) or if ive been sitting at a light or something (idling). Maybe happens once a day or once every 2 days.
raymoon is offline   Reply With Quote
Old 11-17-2012, 02:33 PM   #20
eph6jonprice
My Ride: 2001 330Ci
I'm actually good on the hesitation, but getting a p1192 code that is making ME go nuts, and I definitely get the "kangaroo hopping" on cold starts... even rolling down my driveway when the car is cold gives me the occasional jerk. You said cleaning the ICV and straightening the air hose solved this? Do you have a thread or DIY on it? I would be VERY grateful... just spent most of my Saturday in the freezing cold checking, replacing, and plugging vacuum lines in the proper place and it's STILL doing it! Thanks!
eph6jonprice is offline   Reply With Quote
