Old 09-09-2011, 08:39 PM   #41
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
I love mine and it sounds even better with the turbo.
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 09-09-2011, 09:37 PM   #42
rkneeshaw
My Ride: 330i ZHP
Originally Posted by hokiebimmer View Post
How did the x-pipe affect the zhp exhaust tone?
It didn't really effect it at all, not that I could really notice anyway. That resonator that it replaced is so small I can't imagine it was doing much
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is online now   Reply With Quote
Old 09-10-2011, 05:59 AM   #43
Bmw_fever
My Ride: 01' 325i ZSP ZCW
my exhaust is on backorder fuuuuu
Bmw_fever is offline   Reply With Quote
Old 09-10-2011, 08:08 AM   #44
Au2bahn
My Ride: 05 330i ZHP,09 HCHII
Where did you order it from
Sent from my DROIDX using Bimmer
Jon Estrella
ESS TS2 - VMR V710 19" wheels - KW Coilovers - 3.46 Diff - Macht Schnell 5mm Rear Spacers - BMW Performance BBK w/ floating rotors -
BMW Performance Strut Brace - BMW Performance Air Intake - BMW Performance SSK/DSSR - Hawk HPS Brake Pads - SS Brake Lines -
OEM M3 RTAB w/ Vorshlag Limiters - Meyle HD FCAB - TMS Sway Bars w/ adjustable links - AEM Digital Boost Gauge -
Stewart w/p - 6K HID Fogs - Swain Coated Magnaflow headers
Au2bahn is offline   Reply With Quote
Old 09-10-2011, 06:43 PM   #45
Bmw_fever
I ordered from performance peddler who source it directly from magnaflow
Old 09-14-2011, 08:51 PM   #46
chanlon7
My Ride: 03' BMW 330xi
we need more quality videos of this catback with headers... cause, I'm awaiting the catback, but have time to change my mind.
HR Sports, Konis, Tints, Angel Eyes, Black headliner swap, BimmerBrakes Headers
Gruppe M Intake, Clear tails/markers/corners, Alufelgen SF-71 Black Diamonds, Magnaflow Catback
chanlon7 is offline   Reply With Quote
Old 09-14-2011, 09:16 PM   #47
Steven747
My Ride: 05 330ci
i got a defective batch no bueno.
Old 09-15-2011, 06:18 PM   #48
gdaddy
My Ride: 2004 330i zhp
I am in for the next batch as mines is on back order as well....hope this time around things are 100% all good.
gdaddy is offline   Reply With Quote
Old 09-15-2011, 07:38 PM   #49
Bmw_fever
What do you mean a defective batch? Is this something I need to worry about?
I'm in Canada so I really don't want any surprises.
Old 09-15-2011, 07:46 PM   #50
chanlon7
Mine shipped today...
Old 09-23-2011, 11:50 PM   #51
gdaddy
got mines installed. I have the howling sound I am NA and the sound comes in a higher RPMs...
Guess Magnaflow did not fix the problem...or is it the actual install? I read that there was a bad weld, where is the location of the bad weld?
Old 09-24-2011, 08:46 AM   #52
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
hmmmm
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 09-24-2011, 10:25 AM   #53
gdaddy
I will re-check all the clamps and nuts to the header/cat next weekend. But all seems tight as far as exhaust leak noise. higher RPM's will yield a howling/whistling sound...
bigjae- did you ever figure out the root cause to your exhaust howling.
Old 09-24-2011, 12:54 PM   #54
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
If it were me, I'd very securely jack up your Bimmer on all 4 corners. Then with you & a buddy I'd start up the car & while one of you lays near or under the car (if you're brave) the other takes two tennis balls & holds them (wearing gloves) into the muffler outlet. This few seconds of back pressure will not shut off the motor, but should be plenty to show if you have an exhaust leak somewhere in the system.
Mine sounded great the first time, I really hope you get this fixed.
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 09-24-2011, 02:33 PM   #55
bigjae1976
bigjae1976's Avatar
nope...gonna try to get a new one under warranty.
Old 09-28-2011, 12:56 AM   #56
chanlon7
installed mine on a 330xi today. sounds pretty sweet. Think I'm going to have to order a new transmission exhaust support. Mine wasn't even there haha. Sooo, hopefully this will help reduce some rattle. Sounds pretty BA, its definitely loud. A little louder than I was expecting but its nice with cruising, and a lot of deep growl.
I essentially just shifted the resonator further down the exhaust to make it fit...
Old 09-28-2011, 01:34 AM   #57
Rob43
Rob43's Avatar
So let me get this straight, this is a #16533 on a 330XI ? If your modification is what it takes to get it on the XI, then you should take a lot of really good pics. This way everyone else with an XI can get it, & do your modification for installation.
Old 09-28-2011, 09:43 AM   #58
chanlon7
well, those are the pics that show exactly what was modified. It was cut right behind the first resonator. And then used a 2 inch pipe to extend the distance between the header/exhaust flange and the first bend in the exhaust.
Everything else fit perfect.
Old 09-28-2011, 10:16 PM   #59
rkneeshaw
My Ride: 330i ZHP
Thats pretty cool chanlon. An easy modification for any exhaust shop, doesnt even look like they had to make a single bend.
2003 BMW 330i ZHP
Old 09-29-2011, 07:56 PM   #60
chanlon7
yeah, no bends, fairly straight forward... It really roars man haha. I think I need to makeshift some more rubber brackets.
