Old 09-29-2011, 10:12 PM   #61
rkneeshaw
My Ride: 330i ZHP
For sure. the more I drive it the more I like it. At first the bit of rasp from 3k-4k RPM's was bothering me, now I think I kind of like it. It really roars at WOT, the sound is awesome
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 09-30-2011, 10:42 PM   #62
gdaddy
My Ride: 2004 330i zhp
Smile
Originally Posted by Rob43 View Post
If it were me, I'd very securely jack up your Bimmer on all 4 corners. Then with you & a buddy I'd start up the car & while one of you lays near or under the car (if you're brave) the other takes two tennis balls & holds them (wearing gloves) into the muffler outlet. This few seconds of back pressure will not shut off the motor, but should be plenty to show if you have an exhaust leak somewhere in the system.
Mine sounded great the first time, I really hope you get this fixed.
Good luck.
All good now, reinstalled my support bracket (old one broke while I was trying to remove it), used washers for cross brace (no more rattle while going over bumps) and re-tightened the clamps (weird howling noise gone)..now it sounds 110% better.
I used M8 1.25 pitch/30mm hex bolts with matching washers.
gdaddy is offline   Reply With Quote
Old 10-01-2011, 10:12 AM   #63
rkneeshaw
My Ride: 330i ZHP
Good to hear gdaddy! I hear those clamps can be a pain in the ass. I struggled with mine a bit too.
2003 BMW 330i ZHP
Old 10-01-2011, 10:15 AM   #64
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Good to hear. I've really torqued down on those clamps...still howls.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 10-03-2011, 02:51 AM   #65
AnotherFanatic
Banned
My Ride: a car
Would you guys still reccomend this exhaust in light of all these issues??
AnotherFanatic is offline   Reply With Quote
Old 03-06-2012, 09:30 PM   #66
Zach330ci
My Ride: 2002 330ci
Will I have the vibrating issue on a 5 speed? It any other issue? If any one has experience please help me out!
Zach330ci is offline   Reply With Quote
Old 03-06-2012, 10:13 PM   #67
Steven747
My Ride: 05 330ci
not me i have a deffective 1 and haven't found the time to send it in and get a warranty repair
Old 03-08-2012, 10:14 PM   #68
rkneeshaw
My Ride: 330i ZHP
steven I think you're the only person I've heard who's had that problem.
2003 BMW 330i ZHP
Old 03-09-2012, 12:14 AM   #69
Bmw_fever
My Ride: 01' 325i ZSP ZCW
Look at gdaddy's post, I had the same issue it's because the pipes are a larger diameter and the rubber support on the bracket isn't thick enough avoid the rattling. Just install some bushings and you're fine.
Bmw_fever is offline   Reply With Quote
Old 03-09-2012, 09:16 PM   #70
Steven747
My Ride: 05 330ci
ohh really have you read any posts on this page..:face palm: bigjae has the same exact issue
Old 03-09-2012, 09:28 PM   #71
rkneeshaw
My Ride: 330i ZHP
ok then, there's two of you. I think its a rare issue. It does have a warranty on it so I don't know why you didn't just take care of that.
2003 BMW 330i ZHP
Old 03-10-2012, 01:05 PM   #72
bigjae1976
bigjae1976's Avatar
Magnaflow with AA headers...
I've replaced the front and rear section under warranty. My mid section has an O2 bung for my AFR gauge sensor welded into it. Maybe the x-pipe or the bung is causing the screeching. I had some shop in South Korea do it...let's say its not a very pretty weld.
Old 03-10-2012, 10:37 PM   #73
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
That thing sounds like one of those new hybrid E46 / F1 cars !
SUMMIT POINT WV 1:24:229 SCCA
Old 03-10-2012, 11:25 PM   #74
TitanSl33pr
My Ride: 330ci
That was so sick :-o!!!!
Sent from my Samsung Galaxy using Bimmer App
TitanSl33pr is offline   Reply With Quote
Old 03-11-2012, 12:11 AM   #75
Steven747
My Ride: 05 330ci
It's not as easy as you would think.. I hate to borrow a exhaust for at least a month
Old 03-11-2012, 12:09 PM   #76
bigjae1976
bigjae1976's Avatar
I went through Hot Exhaust who was the original distributor of this exhaust. They sent me a new exhaust, charged my CC, I replaced the 2 sections, sent everything back and then I got a refund. The risk is there's a chance that magnaflow may not warranty it...although Hot Exhaust said you should be good to go unless you've modified it.
But yeah, it was still a PIA.
Old 03-11-2012, 12:12 PM   #77
bigjae1976
bigjae1976's Avatar
Sometimes I like it but it gets anooying at other times. Its good for waking up the neighbors. I also like passing women talking on their cell phones with the windows down...it will usually give them a nice surprise.
My car is usually one of the loudest at the track...except for the straight pipe porsches and the occasional stock car. So I'm screwed at a track with any kind of noise restrictions.
Here's a video where I stay out of the "screeching" range of the RPM band...you can hear me coming in the very beginning.
Old 03-11-2012, 04:23 PM   #78
rkneeshaw
My Ride: 330i ZHP
Too bad we weren't closer, I'd let you borrow my stock ZHP exhaust.
2003 BMW 330i ZHP
Old 03-12-2012, 11:24 PM   #79
Steven747
My Ride: 05 330ci
Old 03-15-2012, 01:02 AM   #80
Steven747
My Ride: 05 330ci
currently on the hunt for the cheapest possible stock exhaust
