Old 08-02-2011, 11:33 PM   #1
theone_06
My Ride: 330Ci Zhp 2004 White
Found My oil Leak! please help!
So I started the car for a few minutes and right before leaving I saw smoke coming out of the hood, so I go and check out and it was alllll thereee the oil ive been spanding on the car !
watch pictures in orders and please help me find whats the cause of that leak.
25mm H&R Spacer Back
15mm H&R Spacer Front
AFE Cold Air Intake
HighLine Full Exhaust
theone_06 is offline   Reply With Quote
Old 08-02-2011, 11:33 PM   #2
theone_06
humm I cant post pictures?!
AFE Cold Air Intake
Old 08-02-2011, 11:36 PM   #3
GuitarmanTT
My Ride: 1999, E46 328i
Valve cover gasket. Easy DIY good luck
http://desmond.imageshack.us/Himg231/scaled.php?server=231&filename=img20110608111530.jpg&res=medium
GuitarmanTT is offline   Reply With Quote
Old 08-02-2011, 11:50 PM   #4
theone_06
you can see the pictures?!
AFE Cold Air Intake
Old 08-03-2011, 01:04 AM   #5
MindFK
My Ride: 330Ci
no
MindFK is offline   Reply With Quote
Old 08-03-2011, 01:19 AM   #6
Steven747
My Ride: 05 330ci
assuming
Old 08-03-2011, 06:23 AM   #7
dmax
Stay stock my friends!
dmax's Avatar
My Ride: '99 328i 1.03809 mu
Run finger under engine cover on passenger (rt.) side.
Look for burned oil stains on exhaust manifold heatshield...the two aluminum 'fins' running along the rt. side of engine, just below the cover.
If you see brown on the aluminum, 99.9% valve cover gasket.
It's a common rite of passage here!
Photos probably would help, and you 'can' post them...scroll down to 'manage attachments.'
Doug
This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe."
The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax
Old 08-03-2011, 09:49 AM   #8
mcaden
My Ride: 2005 330i ZHP
Do a search using the term VCG (valve cover gasket) and DIY... and it you will get everything you need (assuming you have a VCG leak -- also search "burning oil smell"). The VCG is an easy DIY. Depending on your mileage... you may want to consider changing your spark plugs while your in there. That will only add about 10 minutes to the job. Others may suggest VANOS seals... but I will leave that to you. Good luck.
-Marc
mcaden is offline   Reply With Quote
Old 08-03-2011, 11:27 AM   #9
killj0y
My Ride: 2000 323i
I doubt this is your problem, but it is a common oil leak also. Search for oil filter housing gasket.
killj0y is offline   Reply With Quote
Old 08-04-2011, 01:22 PM   #10
ECSTuning
ECSTuning's Avatar
My Ride: BMW
It an easy fix, if that's the main cause , which most of the time it is.
Click here for Valve Cover Gasket.
Here is a DIY link to follow.
Good Luck and hope things work.
Best Joe
800.924.5172
Old 08-04-2011, 01:42 PM   #11
Bimmer37
My Ride: 2003 BMW 330i
Thumbs Up
-Marc
word
Bimmer37 is offline   Reply With Quote
Old 08-08-2011, 02:13 PM   #12
theone_06
thanks everyone! just received the gasket, and about to install it!
AFE Cold Air Intake
