Old 08-03-2011, 10:44 AM   #1
computerwhiz1
My Ride: 2000 323i Sedan
Do these headlights need adjustment? (Halogen Reflectors)
I know that halogen headlights are nothing compared to projectors, but come on. I have driven other cars with halogen headlights and they preform much better. I have had some people tell me that BMW headlights are made to point low from the factory so people don't shine them to high and blind other drivers, but man, these headlights aren't good for much. I end up driving with my brights on most of the time (when appropriate of course). So, look at the picture below and let me know what you think. As good as it can get, or needs adjustment? I can post up better pictures if needed.
Name:	Photo Aug 02, 8 03 26 PM.jpg
computerwhiz1 is offline   Reply With Quote
Old 08-03-2011, 10:49 AM   #2
afstud
My Ride: 2003 ZHP 6-speed
please post a much better pick and one thats the correct orientation, but from what i can see, id say yes, and maybe the bulbs arent sitting right in the housing... mine werent when i got it and now there perfect.
afstud is offline   Reply With Quote
Old 08-03-2011, 10:52 AM   #3
computerwhiz1
I'll post up a good pic tonight, once it is dark again. And Im 99% sure the bulbs are seated correctly as I recently changed them out and everything seems to be locked into place good.
Old 08-03-2011, 10:53 AM   #4
Lusticles
My Ride: 325Ci
Bad lenses can affect light output
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 08-03-2011, 11:54 AM   #5
jcns
My Ride: California
if your lights were straight before replacing the bulbs, your new bulbs are not seated correctly.
jcns is offline   Reply With Quote
Old 08-03-2011, 01:59 PM   #6
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Make sure they're seated, get new lens for $80 (think I got mine from rmeuropean...perfect fit).
And, you know, they're adjustable.
Set up against a wall at night on level surface and adjust them as best you can...other drivers will let you know how you did!
You know those white plastic gears you see? Turn in the center with allen wrench. In front is up and down, on the side is right and left.
HTH
See me in June!
dmax on Facebook
Mangofy your E46!
Old 08-03-2011, 02:07 PM   #7
computerwhiz1
They have been messed up even before i changed the bulbs.
Old 08-03-2011, 02:09 PM   #8
computerwhiz1
HTH
The lenses look to be in pretty good shape. They are not oxidized and they only have a few marks on the from road debris or something. I'm planning a big weekend of DIY this weekend, so I will see what I can do as far as adjusting the headlights then. The only problem is the instructions i found required one to back their car of 25 feet from a wall on a level surface. Such locations seem to be in short supply around where I live.
Old 08-03-2011, 02:28 PM   #9
dmax
dmax's Avatar
You can use a home depot wall; there will be flat places around. Also, although there is an exact center of the light pattern, I also know it can be a pain to get exact. Again, just let other drivers tell you when it's too high or wide!
See me in June!
dmax on Facebook
Mangofy your E46!
Old 08-03-2011, 02:40 PM   #10
afstud
the bulbs can be seated two different ways and will seem like there fit properly but there is only ONE correct way to seat them in the socket, the notch of the H7 bulb (where it has the square part on the metal base) that should be in between the two prongs that are further apart, when i took mine out they were the opposite and looked just like how yours do. and when the bulbs are mounted correctly they should make a very nice cutoff with a slant on the passenger side like this __/
adjustment, halogen, headlights
