door problems - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 08-03-2011, 06:24 PM   #1
3 pedals
My Ride: 2001 325xi
Question door problems
im switching my passenger side front door.got everything to work but i cant get the two 10mm bolt/screws on the top and bottom of the hinges to go back in. the door swings but its not lining up properly when you try to close it. any suggestions any advice would be helpful.thanks
3 pedals is offline   Reply With Quote
Old 08-03-2011, 07:36 PM   #2
Fred The Puppy
My Ride: 330XI
Door swaps go easier if you use the entire hinge assembly from one car/door or the other. Also, be sure that you installed the spacer plate between the door and the hinge. If you don't have the entire assembly from the donor car, take the hinges from the original door. Once everything is together again, you may need to shim one of the hinges to make door gaps perfect.
Fred The Puppy is offline   Reply With Quote
