E46 Xi Forum
Old 08-04-2011, 01:37 AM   #1
jerryscott
My Ride: 2002 325xi
Transfer Case and Dexron Vi
I went into BMW last week to get some oil to change in the transfer case and the parts counter was trying to tell me the transfer case takes dexron vi oil. I argue with them for a bit and gave them the part number of the transfer case oil and they came back and said it's been changed to dexron vi for the transfer case. are they BSing me or what ? I've done lots of searching but haven't found anything to confirm this
jerryscott is offline   Reply With Quote
Old 08-04-2011, 06:23 AM   #2
Fred The Puppy
My Ride: 330XI
Ya, Both the GM auto transmissions and transfer case use Dexron VI. The Texaco ETL stuff originally used is no longer available or recommended by either BMW or GM. Use whatever oil you have leftover from a transmission fluid change, since the TC only holds a few ounces; Redline D4, Castrol all-import, Dexron VI are all fine. I personally use the Castrol.
Fred The Puppy is offline   Reply With Quote
Old 08-04-2011, 08:55 AM   #3
ferngreen 325xi
My Ride: 2001 325XI wagon.
I used to use Redline D4 in the TC but at the advise of some of the members of this site, I switched to Redline MTL. It's closer to the original BMW fluid viscosity spec and it made the TC in the car a little quieter on the highway.
ferngreen 325xi is offline   Reply With Quote
Old 08-04-2011, 10:53 AM   #4
WilliSverige
My Ride: '98 Volvo V70 AWD M
I used Redline MTL in the TC the first time I changed it - ran that for one oil change interval (7500 miles) and then flushed that out with Amsoil 75w90 GL-4 MTF. It's a little different viscosity than the Redline but similar specs. The transfer case is quiet and I plan on running this fill for about 40K miles.
WilliSverige is offline   Reply With Quote
Old 08-05-2011, 01:21 AM   #5
jerryscott
My Ride: 2002 325xi
thanks for the replies I just wanted to confirm what was correct before changing fluids and making a mistake
Old 10-06-2011, 07:30 PM   #6
A3ferthee
My Ride: 2003 330Xi
I used Pentosyn 75w80 in the TC and Amsoil ATF for the tranny.
A3ferthee is offline   Reply With Quote
Old 10-06-2011, 08:17 PM   #7
e46alfonso
My Ride: 330xi MT, mustang gt
these threads are a bit old. just saying
