Go Back   E46Fanatics > Everything Else > The Off-Topic > Money Matters
Money Matters
Financial, Stock, Investment etc. posts here.
Old 08-04-2011, 05:05 PM   #1
Raymond42262
My Ride: Is German
When do they stop trading ?
What are the rules to stop trading on the NYSE when the market drops too far?
After a brief search I could not find it on the net.
512 points is a lot for the market to drop in one day.
It dropped 4 percent.
I think the benchmark is 5 percent before they delay trading.
Is that right ?
Raymond42262 is offline   Reply With Quote
Old 08-04-2011, 05:08 PM   #2
evolved
My Ride: 2006 Mazdaspeed 6 GT
They call them circuit breakers.
http://usequities.nyx.com/markets/ny...rcuit-breakers
Xbox: LucasTheLush
Present
LPM 2006 Mazdaspeed 6
Cobb SRI//Cobb TIP//SLS Test Pipe//AWR Rear MM//AutoExe CF Grille
Past
2000 BMW 323ci //Topaz Blue
2003 Evolution VIII
1995 Nissan 240sx w/ SR20DET
evolved is offline   Reply With Quote
Old 08-04-2011, 05:43 PM   #3
Raymond42262
My Ride: Is German
Originally Posted by evolved View Post
Thanks, I guess the drop has to be more extreme.
Rule 80B
Effective April 15, 1998 the SEC approved amendments to Rule 80B (Trading Halts Due to Extraordinary Market Volatility) which revised the halt provisions and the circuit-breaker levels. The trigger levels for a market-wide trading halt were set at 10%, 20% and 30% of the DJIA, calculated at the beginning of each calendar quarter, using the average closing value of the DJIA for the prior month, thereby establishing specific point values for the quarter. Each trigger value is rounded to the nearest 50 points.
The halt for a 10% decline would be one hour if it occurred before 2 p.m., and for 30 minutes if it occurred between 2 and 2:30, but would not halt trading at all after 2:30. The halt for a 20% decline would be two hours if it occurred before 1 p.m., and between 1 p.m. and 2 p.m. for one hour, and close the market for the rest of the day after 2 p.m. If the market declined by 30%, at any time, trading would be halted for the remainder of the day.
Under the previous Rule 80B trigger points (in effect since October 19, 1988) for a market-wide trading halt, a decline of 350 points in the DJIA would halt trading for 30 minutes and a drop of 550 points one hour. These trigger points were hit only once on October 27, 1997, when the DJIA was down 350 at 2:35 p.m. and 550 at 3:30, shutting the market for the remainder of the day.
