Old 08-06-2011, 05:41 PM   #1
kay9
My Ride: bmw
Coolant light problem helpppp!
bmw 318i 2002 petrol
expansion tank was cracked changed (107k)
now the COOLANT SIGN wont go OFF
bleed the system
coolant is fine been driving for a month
temp gauge is fine stays in the middle
also I have no hot air coming into the cabin, just could air, only when i set the temp setting to HIGH hot air comes
any ideas please
kay9 is offline   Reply With Quote
Old 08-06-2011, 05:58 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Cribs: add coolant/distilled mix
Let car cool down.
Add coolant. Read about 50 bleeding threads! You don't have heat because of improper filling/bleeding of system. You evidently just noticed it because you maybe put on the heater, sucking up coolant, triggering low coolant light.
Add coolant or just distilled water...if you guys do that there! We're snobs here, many of us only give our cooling systems the finest in distilled water! You probably should too!
F! I can't write a short post...
Read a lot anyway, OP, but you should add a 50/50 mix of the coolant you used and distilled. If it's only a couple cups low...it is...distilled is fine unless you get really cold there.
I reread the part about heat...so you have heat when you turn on the heat, but you don't have heat when the heat isn't on? I think you meant something else...but the answer is still 'add coolant'
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 08-06-2011, 06:51 PM   #3
CoupeMagic323ci
My Ride: 00 323ci
PS3N ID: siberiasurvivor
CoupeMagic323ci is offline   Reply With Quote
Old 08-06-2011, 06:54 PM   #4
dmax
dmax's Avatar
Originally Posted by CoupeMagic323ci View Post
How else could I have asked that?
Mangofy your E46!
Old 08-07-2011, 04:31 AM   #5
kay9
My Ride: bmw
Any methods of bleeding the system correctly
Old 08-07-2011, 04:41 AM   #6
dmax
dmax's Avatar
I think you just need to add coolant. If you did work a while ago, the bubble has probably come to the ET already, and you'll find your coolant low.
If not, you've got another issue.
If you want, I don't think you need to, but...
Key to Pos 2; car NOT started.
Heat on highest temp
Fan on low
Dial to three red dots
Open ET, bleeder screw...add coolant SLOWLY until coolant starts leaving bleeder screw bubble free.
Close up, start the car, drive around neighborhood to OP TEMP, and if it ever rises above dead center on temp gauge, get home, stop car, get back here and report.
If you don't overheat, get home anyway after getting to op temp. Let it cool, check level...it might be high.
That's why, for now, I think you should just add coolant as needed so you're between the min and max balls on dipstick.
Monitor coolant level periodically...more often after having any issues with it.
Mangofy your E46!
Old 08-07-2011, 03:50 PM   #7
kay9
My Ride: bmw
coolant keeps overflowing out when toping up
Old 08-07-2011, 03:53 PM   #8
dmax
dmax's Avatar
If you're just adding coolant, like I said, fill it so that the two balls on the floating stick, straddle the top of the filler neck.
The coolant itself should be about 5.5" below the filler neck.
You need air space above it.
Did you fill it to the top and drive and then it overflowed, or it's overflowing because you have the car running with the cap off?
In any case, get the car cool and adjust the level like I said.
If I misunderstood, let me know, British English is my second language!
Mangofy your E46!
Old 08-08-2011, 02:27 PM   #9
kay9
My Ride: bmw
coolant is topped up fine the red stick is where it should be
but i tried it with the heater on like you said but it keep coolant keeps overflowing out when trying to top up
Old 08-08-2011, 02:37 PM   #10
dmax
dmax's Avatar
Did you start the car? If so, I meant just add coolant when car is off.
The stick should not be all the way up, right...balls above and below the filler neck.
You have your bleeder screw closed?
If the car is on, turn it off, let it cool down.
Then open cap, check level, adjust as needed. Don't start the car, don't turn on the heater, just start with that.
Close things up, drive to op temp staying in the neighborhood. Get home when at op temp or just before...let it idle to op temp...turn it off, let it cool down. Open up ET and see what the level is at.
I think I wrote to do something like this first below...
(When you say it's overflowing, is it pouring out that little screw to the right of the ET cap, the bleeder screw? If so, it should be. If not, are you sure you opened the bleeder screw?
Mangofy your E46!
