Old 08-07-2011, 03:13 PM   #1
peterock29
My Ride: 2002 bmw 325ci
check engine light was a p1028 code?a little help needed
ok guys so i went to autozone the guy was a friend of a friend and checked it and let me know what the code means and it came up p1028 he looked it up and it could be 3 things.one was coolant level second was a thermostat and third was a etc or ect electronic temperature control or something to that effect,(i lost the damn reciept with the info on it at the moment).this came as a surprise to me cause its been very hot on the east coast this summer and ive driven my car in the 2 weeks ive had her about 300 miles.the temperature gauge stays pinned at half never moves when driving or in idle.so i would of never thought it was that.does anyone have any experience with this code?any help is greatly appreciated thanx
peterock29 is offline   Reply With Quote
Old 08-07-2011, 03:14 PM   #2
Guest021715
Account closed.
The code itself means your car is not warming up fast enough.
It could be your thermostat is stuck open, it could be a temp sensor, or it could be just a bad coolant mixture (too much antifreeze, not enough water)
Money is on the first two suggestions.
Old 08-07-2011, 03:17 PM   #3
peterock29
ok sounds about right ,i added 50/50 anti-freeze from autozone just to see if that would get the light to show off cause the dipstick was all the way down when i opened up the radiator cap.but then someone told me my bmw takes special coolant i can only get at the dealer.
Old 08-07-2011, 03:44 PM   #4
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
you can use zerex g-05, prepare for sticker shock
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 08-07-2011, 04:44 PM   #5
peterock29
what does prepare for sticker shock mean?please forgive my inexperience here
Old 08-07-2011, 05:00 PM   #6
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
The stickers on Xerex coolant have a pre-installed static charge to protect the coolant from aging.
JK...but, you shouldn't really mix coolants...what color coolant did you have before?
Look at your gauge carefully next time you drive...when therm is stuck open, on the highway, you'll notice the gauge might drop below normal, even by a little bit, it means the thermostat has failed.
It could be the temp sensor, but honestly, I can't recall ever reading that one has failed. I'm sure they do, but many here just replace it anyway as part of a cooling overhaul.
Also, DO NOT OVERFILL the ET...the balls should straddle the top of the ET's filler neck...coolant should be 5.5" below the top edge of the neck...I measured!
HTH
Facebook.com/DMAXstandup
Mangofy your E46!
Old 08-07-2011, 07:38 PM   #7
peterock29
i think my next step is to get my thermostat changed.and another question is if and when the problem is fixed ,like if the problem is the coolant will the light automatically go off? cause i know some cars the engine light needs to be reset
Old 08-13-2011, 11:32 PM   #8
peterock29
ok the light went off during the week and hasnt come back on.so does that mean it was the coolant level?i know these bmw's are very sensitive with coolants and such
Old 08-14-2011, 01:22 PM   #9
Vault
My Ride: 2005 330xi
I had same code two weeks ago and expansion tank was empty. Filled up coolant and I was good to go!
Plasti Dip Tutorial: [Link]
Vault is offline   Reply With Quote
Old 08-14-2011, 02:08 PM   #10
peterock29
im hoping this was it.if i have to do more work i wont be devastated but if it was a simple coolant problem ill be ok with that i love my car
Old 08-14-2011, 02:14 PM   #11
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Please use BMW Coolant and Distilled Water. The BMW cooling system is not designed to handle anything else.
Putting Autozone coolant in there will make your CE light the least of your worries.
see this video:
delmarco is offline   Reply With Quote
Old 08-14-2011, 02:25 PM   #12
peterock29
someone in this thread said to use zerex g-06 stating its the same as bmw coolant
Old 08-14-2011, 02:32 PM   #13
delmarco
what is xerex g-06?
sounds like a comic book villian
Old 08-14-2011, 02:36 PM   #14
peterock29
im pretty new to the whole coolant world.especially with the sensitive bmw type antifreeze.id really need a run though when i do it since your saying to dilute it with distalled water,ive never heard that before.but i wanted to flush the coolant for sure and do the zerex one or if your saying the bmw one id do that instead just to be sure.
Old 08-14-2011, 02:38 PM   #15
delmarco
peterock -
BMW Coolant is $19 a jug
that Xerex stuff seems pricey!
After all it is gold coolant that last 5 years and 150,000 miles!
Old 08-14-2011, 02:43 PM   #16
peterock29
id have to go to a bmw dealership to get the bmw blue coolant?for $19 that seems less expensive than i thought.
Old 08-14-2011, 02:46 PM   #17
delmarco
The price may have went up but It will still be around $19 to $22 a gallon. Green Generic Autozone Coolant is like 3.99 a gallon I think so $19 is expensive.
Old 08-14-2011, 02:49 PM   #18
peterock29
ill spend the $20 for the bmw jug.ill only need one jug?once i get it is it ok to message you for just a safety run through to dilute it and everything.i just want to be certain im doing it right and i dont want to harm my baby in anyway thank you for all the help already
Old 08-14-2011, 02:54 PM   #19
delmarco
yeah...let us know what happens. All you need is the one jug.
good luck pete rock.
Old 08-14-2011, 02:57 PM   #20
peterock29
thanx when i get the coolant and get a few minutes to do it i just need to know how much water to dilute it with before adding it in
