Front coilover setup won't lower? threads at lowest possible setting! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 08-07-2011, 03:39 PM   #1
DHNT2005
My Ride: is a money pit.
Ok, so i've searched and can't find the correct answer to remedy my issue. I have H&R RSS Clubsport coilovers, here:
http://www.europeanautosource.com/pr...roducts_id=895
Installed them and cannot get the front to lower. I have them set at the lowest possible thread and there is a good near two finger gap on both fronts. The rears are at the perfect height. Does anyone have any idea what is going on? Thanks in advance guys.
DHNT2005 is offline   Reply With Quote
Old 08-08-2011, 12:27 AM   #2
DHNT2005
So I had asked Daron (w0w) and it seems as though he had a similar issue with the H&R coilovers. Here is his reply:
"i had the same problem as you. make sure the knuckle is in all the way into the collar on the front struts. i had to use another jack to jack up the control arm til the shock fell into place!"
Could someone elaborate? or better yet, illustrate on this picture? http://www.amazon.com/dp/B002QTOAG8?tag=uj546ro-20
Old 08-08-2011, 01:27 AM   #3
LivesNearCostco
My Ride: 2003 ZHP 6MT
That picture won't help because it doesn't show the steering knuckles. But okay, I don't have any drawing tools handy, but cropped out everything except the bottom of the front struts. These insert into the steering knuckle. A tab or bump on the back of the struts slides into a groove in the knuckle. If strut is not aligned properly, the nub won't slide into the grove so the strut bottom doesn't slide all the way into the steering knuckle and your front end sits too high. Jack up front end, put on jack stands, remove front wheels. Inspect backs of steering knuckles to see if nub on coilover is in the groove. Put jack below knuckle to support it. Loosen pinch bolt on knuckle. Twist strut body if needed to align nub with groove. Slowly raise knuckle with jack until bottom of strut (coilover) is fully seated inside steering knuckle. If that fails, post photos of the back of the steering knuckle with the strut lower end sitting in it.
Edit: OK, now you force me to reveal how bad my drawing skills are in MS Paint using a laptop trackpoint!!! See added image from RealOEM that I've mutilated.
Last edited by LivesNearCostco; 08-08-2011 at 01:35 AM. Reason: Added a modified RealOEM photo
LivesNearCostco is offline   Reply With Quote
h&r coilovers
