E46 Xi Forum
Old 08-08-2011, 07:25 AM   #1
Gus330vrum
My Ride: 330ci
Exclamation Kubica... i need your opinion buddy!
i have changed my suspension ..... bilstein sport / w rear sport m3 1999... from bavauto.com ...... but im hearing a cracking sound from the back ONLY WHEN VEHICLE MAKING A TURN... there is new rear shock mount.... what makes cracking sound when turning the vehicle ?
Gus330vrum is offline   Reply With Quote
Old 08-08-2011, 09:59 AM   #2
Kubica
My Ride: 2003 325xi
Did you use gaskets on the rear shock mounts? Have you gotten an alignment?
Have you jacked up each wheel and shaken it to look for play?
So the problem only started after you did shocks and springs?
Old 08-08-2011, 10:46 AM   #3
Gus330vrum
My Ride: 330ci
yes.. i have put new gaskets on top of the new shock mount...
i will jack it up and look for play....!. ( responde later)
no... the problem was there before too... i was thinking it was the Shock mounts... pull them out... both looking good.. no crack no shaking too much on the rubber ( but i replaced w/ NEW ones)..... sooo what could cause a cracking sound when turning 160 degree angle and when its wave street... liikee....'. front left wheel UP, FRONT RIGHT WHEEL DOWN, then Rear left side down and rear right wheel up... it makes a cracking sound too... like high hill kinda wave road still... causes the cracking sound. when going over bumps too... and car shakes from side to side way to much.... what holds the car from shaking so much side to side? subframe bushing? REAR sway-bar ?
I would think its shocks.... but you go outside and pump the car down, its very hard,stiff.... not too much going down and up.. as if you were jumping the rear up&down... of course - its a rear 1999 m3 shock sport from bavauto.com .. ( e46 bilstein sport known to fail ) i did not want to risk it!.
Old 08-08-2011, 11:10 AM   #4
Kubica
My Ride: 2003 325xi
Ahh! That sounds like a sway bar issue.
Check the links, bushings, and brackets.
Old 08-08-2011, 11:29 AM   #5
Gus330vrum
My Ride: 330ci
hmm.. how i check it for sway bar issue? what would be a good sway bar for bilstein e46 sport / rear m3. / 330 "same year" spring.
Old 08-08-2011, 11:44 AM   #6
Kubica
My Ride: 2003 325xi
The sway bar itself is probably fine. Everything that mounts it to the car is suspect in my opinion. Look at the endlinks and the brackets that hold the bushings.
Old 08-08-2011, 01:14 PM   #7
Gus330vrum
My Ride: 330ci
http://www.bavauto.com/shop.asp
/\/\/\<-is that everything that needs to be changed on the sway bar that mounts to it... on bavauto?
is it okay to have stock sway bar with sport suspension? .. lol.. ;'p
Old 08-08-2011, 03:53 PM   #8
Kubica
My Ride: 2003 325xi
Numbers 2, 3, and 6 here:
http://realoem.com/bmw/showparts.do?...42&hg=33&fg=45
If you want to upgrade, get the HnR rear bar from Turner. It comes with bushings, but you would still need new endlinks and possibly brackets.
Old 08-08-2011, 04:51 PM   #9
Gus330vrum
My Ride: 330ci
okay! but is it necessary to change the sway bar? or just the bushing and ends links... maybe brackets.. its fine... so i wont buy a new sway bar and put the money for front sway bar bushing and end links.. too :-D where u recommend me to purchase there parts?
Old 08-08-2011, 08:23 PM   #10
White_Knuckles
My Ride: 2003 325xi
I've gone ghetto troubleshooting for swaybar sounds. Spray a healthy dose of your favorite lube on links and bushings. You can use the spray can extension tube to squirt into rubber bushing sides. Anyway, after your "lube job", you listen for changes with a quick drive. Sometimes creaks, pops and squawks are worse or completely gone. Either way it's great to know you're on the right track with swaybar issues.
Old 08-12-2011, 07:21 AM   #11
Gus330vrum
My Ride: 330ci
thank you buddy! im do that.... i really appreciate it.... im do that... =D good advice... hehe
Old 08-12-2011, 12:05 PM   #12
Tele
My Ride: E46 330XIT MTech II
Originally Posted by kubica View Post
numbers 2, 3, and 6 here:
if you want to upgrade, get the hnr rear bar from turner. It comes with bushings, but you would still need new endlinks and possibly brackets.
+1
As for the endlinks, read my post with pictures here:
http://forum.e46fanatics.com/showthr...ht=tele&page=4
...you can us the OEM links, but! you will have to use smaller bolts, far too small (in my opinion) for the holes in the H&R sway bar.
Tele is offline   Reply With Quote
