Diesel sound under fuel rail area - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 08-08-2011, 09:45 AM   #1
SILVRRONIN
My Ride: 2003 325.xit
Ok..heres the deal.when I start up in the morning, the car runs fine but I hear aslight sound that is similar to adiesel engine under my fuel rail-oil filter area. I am a nazi for maintenace and I cannot figure out what it is!!! i replaced the disa last year, aluminum impellar water pump 30k ago, flushed with new antifreeze early spring, placed my clutch fan back on for summer months, added water wet to radiator fluid, no codes illuminating, new fuel filter in Dec 2010, ..any suggestions would help!!..
SILVRRONIN is offline   Reply With Quote
Old 08-08-2011, 10:18 AM   #2
Kubica
My Ride: 2003 325xi
Fill your oil all the way up and then add another half quart.
What oil are you using? How old is it?
Old 08-08-2011, 11:43 AM   #3
SILVRRONIN
0-30 wieght.. will do when i get home......... I do have a real
small oil leak from the oil pan gasket- Kubica..your the demi god of BMW repair knowledge. If you rever in New Orleans I owe you a couple of cold beers, a good meal uptown and agood night out with the local ladies. I appreciate your assistance!
Old 08-08-2011, 12:00 PM   #4
Kubica
My Ride: 2003 325xi
Damn my buddy went to Tulane- the girlies down there blow away what we have up here. Let's not get ahead of ourselves though- not positive that's your problem.
Oil pan gasket leak huh? Are you sure its not an oil filter housing gasket leak? I just replaced my OFHG yesterday. Not a bad job- remove alternator, unbolt p/s fluid reservoir, 6 bolts for the housing and you are there.
I too use to use 0w-30, but I switched to Motul X-cess 5w-40 for the summer, and maybe the winter too. Interestingly enough the OFHG didn't leak when the oil was less than 2000 miles old or so. I always change it in about 5k miles.
Old 08-12-2011, 10:27 PM   #5
karatechop5000
My Ride: 03 325xi
I have not had direct experience with the noise you are describing; but I did read somewhere in the general e46 forum about vanos failure making a diesel rattle like noise. Do a search and you may find a helpful video. Good luck.
karatechop5000 is offline   Reply With Quote
Old 08-12-2011, 11:19 PM   #6
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
likely vanos - but, the injectors can make a ticking sound
/_________\
O==[][]==O
