Old 08-08-2011, 12:16 PM   #1
baggyrb4
My Ride: 95 325i sedan
starting problem
Hi i have a 95 325i it has been giving me starting problems for quite a while now. i have to press the accelerator down a little while starting then eventually after a few tries then it will start. would appreciate any advise. i changed my fuel filter and spark plugs same problem.
baggyrb4 is offline   Reply With Quote
Old 08-08-2011, 12:33 PM   #2
Shmo
My Ride: 2000 323i
Send a message via AIM to Shmo Send a message via MSN to Shmo Send a message via Yahoo to Shmo
If you just got it then I suspect alot of replacements/preventative maintenance. Also just FYI this E46fanatics not E36 so the help you get here might not be the best. Someone will chime in and help you out though.
You did pray to your BMW shrine first, asking the Great Roundel for guidance on parts' choices first, right?
Shmo is offline   Reply With Quote
Old 08-08-2011, 12:35 PM   #3
Zchild
My Ride: 2000 BMW 3XXi ZSP
Cool
The folks on the E36 site will probably be able to help you much more than the E46 folks...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 08-08-2011, 12:48 PM   #4
baggyrb4
thanks guys appreciate it, will check the e36 sites. but just in case anyone have any ideas let me know.
Old 08-08-2011, 01:25 PM   #5
Apple4life
Apple4life's Avatar
My Ride: 03 325i SULEV
Fuel pump? Battery? crankshaft position sensor?
Apple4life is offline   Reply With Quote
Old 08-08-2011, 01:31 PM   #6
planejane325i
My Ride: 325i
Check the basics, I do not know what the exact specs are, but you should start with fuel pressure, then move on to ignition. Air+Fuel+Spark+Compression=a running engine.
If the car runs perfect once it starts you can easily rule out air and probably compression. If the car sat for a while, the new fuel filter could be clogged again, along with the filter associated with the fuel pump unit. You could also have a faulty fuel pump, relay, or regulator; a fuel pressure check and careful consideration combined with common sense thinking goes along way in determining a problem. When troubleshooting, always consider the simplest things first. Good luck, and let us know how it works out.
planejane325i is offline   Reply With Quote
