Old 10-08-2012, 09:56 AM   #161
sedanpowersc
My Ride: 330i 5 speed
Would you look at that it's the same part, the almighty zhp doesnt have magical parts?!?!?!?!?!
Cosmos Racing V2 CAI | UUC TSE3 |
sedanpowersc is online now   Reply With Quote
Old 10-08-2012, 11:40 AM   #162
SeanC
My Ride: 330i
Sapphire Black MetallicNatural BrownSilver Cube e46 330i ZHP/ZCW/6MT - Sold
HellrotDove Grey e36 ///M3 - RIP
Alpine WhiteTanSand High Gloss e46 330i SunRoofLess/5MT
For Sale: $300 winter wheel/tire set (sport edition F7s and Dunlop graspics)
For Rent: RTAB Removal/Installation and Preload Tools
SeanC is offline   Reply With Quote
Old 10-08-2012, 11:43 AM   #163
peytonracer4
My Ride: '00 328i
We already knew it had the same part number. Even at the beginning of this thread
Old 10-09-2012, 03:24 AM   #164
TerraPhantm
My Ride: 2005 M3 Coupe
Originally Posted by peytonracer4 View Post
maybe i misremembered that part. but i know the m3 rack is dynamic.
I finally checked - m3 requires 3.2 turns LTL. I really should swap in that 330/ZHP rack I have...
Old 10-09-2012, 09:39 AM   #165
Platinum Plus Quality
My Ride: M54B30
Ahhh the ZHP bug is getting you.. and you drive an M3! it was a 330 rack first, y'know
330 rack 330 rack. the ZHP uses a 330 rack!
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 10-09-2012, 02:31 PM   #166
peytonracer4
My Ride: '00 328i
i've driven on my new rack for one day and autocross with it.
it's a weird transition. i replaced the coupler and tie rods too and its very very touchy. it is nice though.
Old 10-09-2012, 02:34 PM   #167
TerraPhantm
Haha, I just say 330/ZHP to emphasize that they're the same (the one I have actually did come out of a ZHP, but that's only because that's the only one I was able to find at the time)
Well I did have a ZHP before this car so I think I'll be okay with the ratio itself. What I'm somewhat concerned about is the weight of the steering - M3 already feels stiffer because of its geometry... I fear going to a 13.7 would make it unreasonably stiff (there must be a reason BMW only put a 14.5 on the csl, right?)
Old 10-09-2012, 02:41 PM   #168
peytonracer4
My Ride: '00 328i
i really can't comment on why bmw put what rack in what car. the csl was for the euro market. they have some weird tastes sometimes.
i think the major change was the steering coupler though. there's absolutely no give in the steering now so on the highway it's touchy.
i think the feel would be good on the m3. i don't really notice any added effort needed to steer coming from my other rack.
i'd swap it if i were you. it's doesn't take crazy long assuming no issues. so you could always swap back
Old 10-09-2012, 03:00 PM   #169
My Ride: M54B30
Yeah I was just messing with you.
Hmm maybe it's as you said.. shorter ratio would be too twitchy on the autobahn or high speed maneuvering where a longer ratio would allow the driver to more easily control the vehicle at high speeds? ?
Old 10-10-2012, 04:29 AM   #170
TerraPhantm
But it's not like the 13.7:1 rack on the non-Ms was exclusive to the US - if it's not too twitchy for a 330d, why would it be too twitchy for an M3?
And I wonder if hte realized ratio will be any different. I'm pretty sure the M3 has different length tie rods than the non-M... so that will probably effect the realized steering ratio when a non-M rack is installed in an M3.
Old 10-20-2012, 08:21 PM   #171
commandtoad
My Ride: 2005 330i ZHP
i hate to get in the middle of this but i have had some recent experience with this issue and i found out some information that could be helpful.
i wrecked my 04' ZHP. drove over some train tracks, and didn't use the crossing
anyway after replacing all the broken parts, i had no power steering. traced it down to a bad rack. (this turned out not to be true i'll get to that later) wanted to replace with original. did research, read this forum, found lots of controversy. ended up calling rich, the man who actually rebuilds the units and a BMW collector, at the rackdoctor http://rackdoctor.net/Home_Page.html.
after telling him the number on the rack, the last three numbers, 712, on a yellow tag, he immediately knew what i had. he went on to say that this rack IS different than any other rack, even the ones on different cars that had the same ratio. something about the cut and design of the teeth in conjunction with the quick raito. he also went on to say that he had found this rack on a few non zhp cars, but was very rare and no continuity for his findings.
BTW his racks are very reasonable, $150 with his own rebuilt tie rod ends.
side note: my original rack was fine. turned out to be a stuck check valve in the pressure side banjo bolt. never would have thought to look there, found it by accident.
hope this helps....
Name:	rack number.jpg
ID:	474843   Click image for larger version
ID:	474844   Click image for larger version
Name:	bmw track.jpg
commandtoad is offline   Reply With Quote
Old 10-20-2012, 11:44 PM   #172
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
side note: my original rack was fine. turned out to be the check valve in the pressure side banjo bolt. never would have thought to look there, found it by accident.
hope this helps....
thanks for the info and pix.
poor car. what are you going to do with that rack? are you going to sell it?
Old 10-20-2012, 11:48 PM   #173
C00KIE M0NSTER
My Ride: ZHP Coupe
^Drove over train tracks?! Didn't use crossing?!
U WOT M8
<- C is for Cookie ->
'04 ZHP Coupe 6spd
\ - U ///Mirin? - /
C00KIE M0NSTER is offline   Reply With Quote
Old 10-21-2012, 12:07 AM   #174
My Ride: M54B30
He was street racing an M3 (self-admitted in another thread). Not sure i'd buy into anything he says. Also his info sounds... retarded at best
Old 10-21-2012, 12:09 AM   #175
My Ride: M54B30
BTW, anyone with an 02+ 330 has a rack ending with "712"--he'd also immediately know "what you have"
Old 10-21-2012, 02:04 AM   #176
commandtoad
turned the old rack in for a core.
also, before i found the rackdoctor, i had gone to the junk yard and got a rack from a 05' 330ci. it was not the same. it did not have the same last 3 numbers and the tag was purple
as i stated, it is found on other cars, not just the 330, and at the same time, not all 330's have the 712 rack.
why would i lie??? i'm passing on info that was told to me by a guy that does this for a living....
maby if i wrote in crayon and drew some pictures you could understand. i posted a link, call the place yourself, moron.
Old 11-04-2012, 04:52 AM   #177
The Rack Doctor
Regional Sponsor
My Ride: all BMW
Hello I am reluctantly chiming in here in hopes that I may lend a point of view from a technical standpoint. I have had several PM's, e-mails, and phone calls asking me to explain this dilemma over the ZHP Rack. If I may say ahead of time I have no desire to argue fight debate or anything else about the subject I am simply going to try to explain this as it was explained to me By ZF engineers at the AAPEX Expo. as I too (after 26 years of building the rack and pinions) don't claim to know "EVERYTHING" and at times have questions that I need answered. If anyone would like to debate the information please contact ZF.
I am not here to make anyone right or wrong simply offer tech help when I can this is what I always thought that the forums were for a community of enthusiasts trying to help one another.
I took a little time to break down a few pinions to let you see what's on the inside and how they work.
YES the 330 and the ZHP rack share the same turn ratio (3.0 turns let's keep it simple) the racks function differently by the strength of the torsion bar that runs through the center of the pinion (or in simple terms the spool valve ..... I have heard 1000's of names for the pinion)
I am adding a few pictures to try and explain how the units are different I am aware the pinions are not BMW pinions as they are only for the purpose of illustration .
The easiest way to put it is the torsion bar is different in the ZHP rack. As torque is put on the pinion the the more fluid is passed through the pinion. The stronger the torsion bar the more the sport feel. (this is also where the famous over boosted steering comes from a weak torsion bar)
Below is a simple illustration of how a rack works. The torsion bar runs through the center of the pinion (in simple terms the pinion is the brain of the rack it tells the pump when it is turning (torque) give me more pressure to turn the wheels)
The next picture shows the pinions as they would have been removed from a steering rack
The next picture shows the barrel of the pinion taken off with teflon rings still attached
The next picture shows the barrel close up I wanted to show how small the fluid holes are in the pinion so I used a ball point pen for illistration. I wanted to show this so installers will have a better understanding of the importance of flushing the system out prior to installing a rack and pinion. It takes very little to clog these small holes
Ok Moving on the next picture shows the pinion broken down by components the thin bar that runs through the pinion is the torsion bar. This is where the units differ.
The next picture is just a closer look at the torsion bar. Side by side again with a ball point pen so you can get an idea of the size of the torsion bar in the pinion
The last picture is the assembled pinion with a down view so you can see where the torsion bar is in the pinion while it is assembled
I would like to take a moment to thank the forum members for your valued business. I Hope you find the information helpful and we can agree that simply because a rack and pinion has the same turn ratio does not mean that they all perform the same, much the same as on the E36 models the standard E36 and the 96-99 M3 racks have the same turn ratio the racks perform differently. I have a good friend that works for a BMW salvage yard and he tells me that he sells the M power engine covers all the time for people to slap them on their 2.8 L engines we all know that what happens internally is what makes the difference. Adding a ZHP shift Knob to your car does not make your car a ZHP.
We at Rack Doctor go to great lengths to separate these units rather than lump them all together so that when you order a rack you will get the specific rack you are looking for.
Thank you for taking the time to read through this, and again I hope you find it informative. I hope I have explained it well enough, feel free to shoot me an e-mail if you have any questions, or give me a call I will try to help whenever I can.
Be well
Rich (aka the Rack Doctor)
The Rack Doctor is offline   Reply With Quote
Old 11-04-2012, 07:40 AM   #178
Zell
Wears carbon fiber boxers
Zell's Avatar
My Ride: 330Ci ZHP 6sp
This thread just got epic.
Now that we know they are in fact different, how did BMW differentiate them at the factory?? There has to be some sort of way to tell externally, otherwise that would be a quality control/inventory nightmare.
E46Fanatic's resident mathemagician
Old 11-04-2012, 07:55 AM   #179
///MPR77
My Ride: 323i ZSP/ZPP
Rich, Thanks for taking the time to share your wisdom, and experience on this subject.
Originally Posted by ///MPR77 View Post
Some say his notoriety is so profound, that he was able to drop the e46 in his name, and just like "The Highlander" there can only be one....all we know is he is called "Mango"
///MPR77 is online now   Reply With Quote
Old 11-04-2012, 07:59 AM   #180
peytonracer4
My Ride: '00 328i
:o wow. So... This is interesting.
Yes it would be nice to know how bmw told them apart. If the zhp rack is one ending in 712 it would seem that other 330s received the same rack other than the zhp cars
