Old 08-08-2011, 11:51 PM   #1
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Dyno Comparisons: Dynojet,mustang....
Like the title says: I've been talking with a lot of different motor builders / Dyno shops trying to get a somewhat accurate calculation on all the popular Dynos E46Fanatics forum members use. There has always been some confusion when one forum member posts great results for his/her Bimmer, and then another forum member with almost or exactly the same high performance parts yields a way lower (or higher) dyno number. The fact is, different dyno manufactures yield different dyno results. I recently came across this comparison online, based on my research it's pretty darn accurate.
Now on to the comparison:
"Here is how the various dyno manufactures relate to one another. This is just a comparison of numbers output assuming the same vehicle on the dyno.
The industry leader in number output by far is Dynojet. Their marketing in the mid-90's specifically used the larger output numbers as a selling item.
Next is Mustang, generally about 7% less than Dynojet numbers.
Superflow is about 3% less than Mustang.
Dyna-Pak and Dyno Dynamics are about 3% less than Superflow.
Ok lets make this point again to make sure it's clear. The SAME CAR on the DIFFERENT DYNOS. So our test vehicle output on the various dynos are as follows:"
Dyna-Pak/Dyno Dynamics 200hp
Superflow 206hp
Mustang 214hp
Dynojet 226hp
I hope this helps the next time a forum member puts up dyno results & you're trying to compare them to your results, or someone Else's.
In the end it's not about the numbers, it's about how well your Bimmer is tuned; and how well it works against the competition. (if you have some)
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 08-09-2011, 07:09 AM   #2
mrshelley
My Ride: 2004 330i
One other thing. No matter what, keep using the same dyno if you are tinkering around with your car. That way, you at least you can eliminate one variable.
Also, in racing, everyone else has more power than you. The only reasons why you can keep up is because of better braking and handling.
Old 08-09-2011, 08:11 AM   #3
Michel
My Ride: 330ci
nice, thanks for the info!
so theoretically I dyno'ed 225whp on a dyna-pak, I should be around 250 whp on a dynojet... hmm I'm curious to try this!
Michel is offline   Reply With Quote
Old 08-10-2011, 11:48 AM   #4
SK330ci
My Ride: 02 330ci w/ 3 Pedals
+1
Great writeup!
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 08-11-2011, 04:10 PM   #5
4dr05zhp6mt
My Ride: e66 Monaco Blue
Send a message via AIM to 4dr05zhp6mt
Sorry if its a repost, but a good article on nevertheless .
http://www.dinancars.com/university/
2008 Monaco Blue e66
SOLD05 330i 4dr zhp 6MT Jet Black | AA C38-81 S/C, 80mm pulley, water/meth injection | AA headers | Vac Motorsport 248/256 FI cams |
https://www.4shared.com/account/home...edir=105531274 (link to INPA v5, GTv44, EDIABAS, EasyDIS
4dr05zhp6mt is offline   Reply With Quote
Old 08-11-2011, 04:15 PM   #6
Andy2108
My Ride: SpecE46 & E46 M3
Depends on the kind of racing, but sometimes the races are won in the straights
less time in the corners... more time on the throttle
De gustibus non est disputandum.
