Valve Cover Broken Screws...Help!! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-09-2011, 01:18 AM   #1
bighitbiker3
My Ride: Nothing as of yet.
Alright guys so I kinda effed up, but I don't think it's too big of one. I was replacing my VCG tonight and I was screwing in one of the top 4 that holds the cover on. I was screwing on the top bolt closest to the front of the car to 10lbs on my torque wrench. Maybe my torque wrench wasn't sensitive enough, but it broke off the screw below it that screws into the block (I think?). I know it's confusing but if you've seen it I think you know what i'm talking about.
I have these pictures to explain it. But my question is what are the two screws called? What's the part number or whatever i'd ask for when I call BMW or a shop?
Pics:
Where my finger is pointing is the hole where the original screw that you screw the valve cover onto. I broke the one that goes inside of that hole.
Here is the valve cover top bolt that has a piece of the screw that goes in the above hole in its threads. I need a new one of these (rubber and washer are fine, just need the screw.)
Sorry for the horrible phone pictures. Please tell me what both of the screws part numbers are ASAP!
Thanks so much,
Elliott
Black on Black 330CI - FK Coilovers - My Go-Kart
bighitbiker3 is offline   Reply With Quote
Old 08-09-2011, 01:40 AM   #2
bighitbiker3
Car is a 2003 330ci if that makes any difference
Old 08-09-2011, 03:02 AM   #3
mkodama
mkodama's Avatar
They are actually valve cover NUTS that hold the valve cover on, and you broke the stud that is threaded into the head.
I think the stud is part 26 here: http://www.realoem.com/bmw/showparts...13&hg=11&fg=15
first you are going to need a screw extractor set. You could probably skip the left handed drill bits and use a normal drill bits. I bought this cheapo set as essentially an emergency throw away kit: http://www.amazon.com/Neiko-10-Piece...2873131&sr=8-1
Just drill through the stud making very sure the drill is centered, then after you drill the hole, lightly tap in the extractor with a hammer, and unscrew the stud.
If you are lucky, the female threads will be fine and you just thread in the replacement piece. If not, you will need to learn how to do a heli-coil or other thread repair system to fix/replace the threads first.
Sponsored Links
Advertisement
Old 08-09-2011, 03:07 AM   #4
mkodama
mkodama's Avatar
And don't use a torque wrench of the wrong range on those nuts. You don't want to be using the absolute lowest setting on your torque wrench unless you are positive it doesn't over torque. Usually for torque that low, they need their own special torque wrench. Even so, you need to remember the only point of that nut is to lightly compress the rubber valve cover gasket. It's one of the few cases where under-torquing the nut is better.
Old 08-09-2011, 09:57 AM   #5
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
no need to drill or tap the broken stud. if you remove the Valve cober you will see that your broken stud has a welded/integrated/built in, etc 8mm nut. remove the nut to remove the stud and replace.
this will take you 5 seconds to fix. the good news is that you dont even have to remove the valve cover. use a small 8mm socket to remove that broken stud. make sure you use loctite on your new stud afterward.
you can thank me later dude
see here
http://forum.e46fanatics.com/showpos...5&postcount=11
Old 08-09-2011, 10:30 AM   #6
new//M3fan
My Ride: 77' 924 87' E30
The proper way to tighten the VCG is to hand tighten them until they stop then back out 1/4 or half a turn.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 08-09-2011, 10:39 AM   #7
jhaurimn
My Ride: 01' 330ci
The proper way is to use a torque wrench . I couldn't find a precise enough ft lbs one that wasn't 200$+ so I went and got a in lbs wrench . Very very precise . I recommend it!
Sent from my HERO200 using Bimmer App
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 08-09-2011, 10:46 AM   #8
new//M3fan
I digress. not that I don't have one. But i've been wrenching for quite a while that I don't need one for something as a VCG. I know by feel how much 8 ft-lbs is or 20 ft-lbs. It's not much. I can also feel if the bolt is stretching and about to give with a 3/8's wrench were as with a torque wrench I cannot. Hence Why i've never broken a bolt by over tightening..
VCG studs and bolts are not meant to torque and stretch as you can see how easily they break. Their just mean to hold down the VCG.
Old 08-09-2011, 11:46 AM   #9
jhaurimn
My Ride: 01' 330ci
I understand that for yourself but I don't think the op guy has the same experience as you . I definitely don't have enough to guess torque . More power to you .
PAST
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
Old 08-09-2011, 05:47 PM   #10
bighitbiker3
Thanks guys. I got the new parts from the shop. Going to finish it up today! I'll just lightly tighten them...i'm afraid my muscles will break another one
/sarcasm
Old 08-09-2011, 05:53 PM   #11
bighitbiker3
One more thing? I've read some people dont use locktight on the stud and some do. What do you guys think? Use locktight or not? If so red or blue?
Old 08-09-2011, 06:11 PM   #12
Sanchjer
My Ride: 323i e46 SOLD!
Just use the lock tight to be on the safe side, you can never go wrong with it. Use the blue.
Sanchjer is offline   Reply With Quote
Old 08-09-2011, 06:31 PM   #13
bighitbiker3
Wow my spelling is bad. Loctite*. Thanks so much for your help guys!
Old 08-09-2011, 10:47 PM   #14
flashmeow
Banned User
So did it work? Using loctite is recommended but not required. That stud is not going to come loose due to vibration anytime soon. Like the above member said, use blue loctite.
Sent from my PC36100 using Bimmer
Old 08-09-2011, 11:02 PM   #15
bighitbiker3
Runs beautifully. Thanks guys
Old 08-09-2011, 11:06 PM   #16
modular93fox
My Ride: 1987 R10
I wouldnt take this advice... I do valve cover gaskets all the time, and its never tight and then loosen. I use a 1/4 ratchet with a 10mm deep socket and when it stops it stops, and just a little more. Tigten it with common sense and your be good. If you tighen it and loosen it, what do you think will happen? let common sense answer that one.
clint
and in the picture its #10... #26 looks like an exhaust manifold bolt.
E46 323 swaped 2.8l
E39 LS v8 swap - in progress - motor/trans installed
modular93fox is offline   Reply With Quote
Old 08-10-2011, 12:32 AM   #17
mkodama
mkodama's Avatar
That's bad advice. What does backing out a half a turn even do?
Old 08-10-2011, 01:05 AM   #18
Loaded325i
My Ride: bmw 325i
I just replaced my valvecover gasket last night and i noticed that the bolts stop abruptly and I didnt try to tighten them down after that, and there were no leaks. No need for a torque bar here, u just need experience with these things.
Loaded325i is offline   Reply With Quote
Old 08-10-2011, 07:53 PM   #19
new//M3fan
clint
Old 08-15-2011, 05:43 PM   #20
bighitbiker3
Okay so for some reason a new gasket didn't stop the leak..I put RTV sealant on the half moons, but maybe it wasn't enough? What i'm wondering is if I can do it again with the same gasket? I've driven with it for probably about a week and I still have a leak. How much RTV sealant should I use?
Thanks,
Elliott
