Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > California
California
Northern California Southern California
Old 08-09-2011, 11:28 AM   #1
khangn
My Ride: United States
subframe reinforcement diy
does anyone in LA have experience with this diy? http://www.e46fanatics.com/forum/sho...d.php?t=700468
i was hoping to get some feedback on where to find a welder and how much it might cost.
khangn is offline   Reply With Quote
Old 08-11-2011, 02:12 AM   #2
choleaoum
Ceiling missing!
choleaoum's Avatar
My Ride: BMW 330Ci
Send a message via AIM to choleaoum
im sweating just looking at all the labor on that lol. i can do it but man that is a lot of work.
in my opinion, your lucky to find any mechanic to do all that labor for less then 1000$ it involves welding, dropping the diff, removing sway bars, drivetrain, half shafts, rear trailing arm, the whole actual wheel hub oh man. lol
choleaoum is offline   Reply With Quote
Old 08-11-2011, 02:46 AM   #3
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
talk to mini corsa in NoHo, they just did a subframe reinforcement on my friends m3.
If you don't know how to weld or are learning, i wouldn't do this as your first project. technically, they just have to be tacked in place, but i think the welds have to be hold it somewhat.
SL Blak Soldier is offline   Reply With Quote
Old 08-11-2011, 09:29 AM   #4
khangn
So I have the subframe dropped now and I don't see any cracks! I'll have to give it a closer inspection today, but it looks like I won't need to do any welding after all. Maybe just replacing my subframe bushings will get rid of the rear thump.
I don't have any experience welding. I thought about learning just for this project, but you're right, probably not a good first project for a newbie welder
Old 08-11-2011, 01:05 PM   #5
SL Blak Soldier
make sure you clean the surface all the way to the metal with a grinder or something. the dirt will hide a lot of hairline cracks. and i would still do the reinforcement while youre there.
Old 09-17-2011, 02:25 AM   #6
khangn
i sanded the surfaces down and found no cracks
so i ended up just replacing the bushings and skipped the reinforcement.
@choleaoum, thanks for the springs
Old 09-17-2011, 03:45 AM   #7
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
I hope you put on some new undercoating sealant
although I assume if you were able to do all that work you knew to do that
Drew@Swift Motorworks is offline   Reply With Quote
Old 09-18-2011, 01:45 PM   #8
choleaoum
Ceiling missing!
choleaoum's Avatar
My Ride: BMW 330Ci
@khang, your welcome i knew i recongized your name here lol. i wish i couldve stayed longer but i was drunk and hotel security was already on my case. we weren't even being rowdy.
