E46 Xi Forum
Old 08-10-2011, 07:29 PM   #1
BigLouie
My Ride: 2004 330xi
Axle removal
Working on replacing both front axles as CV joints were worn on '04 330xi. Project moving along very nicely until time to remove axle from front hub. After removing axle nut with 36 mm 12 pt socket and removing everything else to free steering knuckle, the axle will not budge. Gave it a few pretty good whacks with hammer/drift combo and nothing happened. Looked at part breakdown and there does not seem to be circlip on the axle outboard side. Other than rust from moisture penetration, what could be holding this up. Any suggestions welcome. Hoping that this will not require removal of entire lower wishbone and carrier to have axle pressed out........
Thanks,
Louie
BigLouie is offline   Reply With Quote
Old 08-10-2011, 07:40 PM   #2
TiAgXi
My Ride: e46xi, e46m
go to autozone and rent one of these:
it fastens to the hub using your lugs, then screw in the bolt to push the axle out of the hub.
they're just hard to remove sometimes.
TiAgXi is offline   Reply With Quote
Old 08-10-2011, 07:43 PM   #3
BigLouie
My Ride: 2004 330xi
I have a similar puller, but too small. Off to parts store I go.
Louie
Old 08-10-2011, 09:13 PM   #4
BLAU III
My Ride: eat's cars.
wait until you try to get it back in. i had a horrible time getting the axel in the dif. i still don't think its right, have a horrible vibration.
Originally Posted by CollinsE90 View Post
I would battle a pack of wolverines in a porta potty with my hand tied behind my back, yielding nothing but a shake weight taped to my forehead, just to hear her fart over a walkie talkie.
BLAU III is offline   Reply With Quote
Old 08-10-2011, 10:11 PM   #5
TiAgXi
Place the axle partially in the diff then remove and cut away the plastic insert that was in the seal. then push the diff as far into the diff as possible without any major force. place the other end of the axle into the hub. then push on the hub repeatedly with moderate force until the axle clicks into place in the diff.
Old 08-10-2011, 10:36 PM   #6
BigLouie
My Ride: 2004 330xi
Seal Replacement
This is an awesome car. In this economy, I probably could not realistically replace it with a new one. My wife will drive it for a loooooooong time. Given that, would you replace the diff seals. Currently no leak but with 86k on odometer ya gotta wonder.......
Louie
