Sponsored by BAVSOUND
Old 08-12-2011, 05:49 AM   #1
zulfik
My Ride: E46 318i Manual
E46 Business CD - weirdest problem
Hi guys,
This is the strangest thing I have ever come across - hopefully someone here can help.
I've upgraded my cassette deck to a business CD unit. At first everything looked OK but then I noticed that the volume knob - when turning it (not pressing it) turns the unit off!
It breaks down like this -
1. Current knob position - everything works fine.
2. One notch clockwise - unit powers off (clock still appears)
3. Another notch clockwise - unit powers back on but NONE of the buttons work.
4. Another notch clockwise - everything works fine
5. Another notch clockwise - unit powers off
and so on and so on.
WTF???
My undying gratitude to all of you.
zulfik is offline   Reply With Quote
Old 08-15-2011, 06:42 AM   #2
zulfik
Anyone? Anyone??
Old 08-15-2011, 07:45 AM   #3
Arty
My Ride: 1999 328i
Sounds faulty (!)
Can you fix electronics? If not, consider a replacement.
Arty is offline   Reply With Quote
Old 08-15-2011, 10:34 AM   #4
rmepilot
My Ride: Supercharged Tacoma
Send a message via AIM to rmepilot
Chances are, that your internal plastic mount for the volume knob is broke. I had a similar problem with a newer CD53 unit that I purchased from another member. I think this is a common problem with loose volume knobs on this radio.
If you carefully disassemble the radio take the faceplate off, you might be able to repair with a 2-part epoxy. I was able to repair mine with superglue, but should have used epoxy for a more permanent repair.
Hope this helps!
rmepilot is offline   Reply With Quote
Old 08-15-2011, 12:04 PM   #5
zulfik
I'm not much of an electronics expert but taking the unit apart for some epoxy work as rmepilot suggested is definitely an option. I'll give it a try. What's the worse that can happen??
Thanks guys!
Old 08-17-2011, 09:22 AM   #6
SPDSKTR
My Ride: E46 ZHP TS2+ Coupe
It's a security selector switch. It has to be disabled at the dealer for $45 or something.
Kidding.
It just sounds like faulty equipment.
Originally Posted by Brucifer325 View Post
Thread sucks so bad they moved it to the Feedback Forum.
SPDSKTR is offline   Reply With Quote
business cd, e46, knob, problem
