Old 08-13-2011, 10:32 PM   #1
Herbalicious
My Ride: 330ci, M3, Z06
What is this hose? Need help!
Trying to help my neighbor out with his ride....
What is the hose I have highlighted in the pic below?
Where does it go?
What does it do?
I've searched!
Thanks!
Herbalicious is offline   Reply With Quote
Old 08-13-2011, 10:49 PM   #2
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
fix pix
delmarco is offline   Reply With Quote
Old 08-13-2011, 10:55 PM   #3
Herbalicious
What is this hose
Sorry...here is pic
Old 08-13-2011, 11:03 PM   #4
Hornung418
My Ride: '04 MB ZHP
It's not a hose. It's a Cable. You've highlighted two different hoses thinking they're one. The one on the right is the Battery Cable. The one on the left is a Wire Casing. They seem to be in their proper positions.
Hornung418 is offline   Reply With Quote
Old 08-13-2011, 11:10 PM   #5
Herbalicious
The battery cable continues passed the hose when it bends...
Old 08-13-2011, 11:18 PM   #6
Hornung418
My Ride: '04 MB ZHP
...And goes to the Starter Motor.
Old 08-13-2011, 11:22 PM   #7
Herbalicious
no...from the other end of the hose
battery cable goes straight and another cable/hose bends down into the side of the engine
Old 08-13-2011, 11:24 PM   #8
Hornung418
My Ride: '04 MB ZHP
Yeah, that's the Coil Harness. It goes into the DME Box in front of the driver.
Old 08-13-2011, 11:25 PM   #9
Hornung418
My Ride: '04 MB ZHP
Take that casing apart...and you will see exactly what's going on. It's really quite simple.
Old 08-13-2011, 11:26 PM   #10
Herbalicious
got ya...trying to figure out a vac leak for a friend
Old 08-13-2011, 11:33 PM   #11
Hornung418
My Ride: '04 MB ZHP
Smoke test should have been the first place to start. There's a maze of Vacuum lines. Coincidentally, none of these things are near Vacuum lines.
Old 08-13-2011, 11:46 PM   #12
bwallace530
My Ride: 325
Get some carb cleaner and start spraying it around in sections when the idles rasies you have found your vac leak.
A couple I had where right on top of the intake boot where the F coupling is.
And the other was going to the sap there is a vac line running on the side of the block pass side going to the egr vavle on the block.
But carb cleaner is really your best bet very easy and you will find your leak fast.
bwallace530 is offline   Reply With Quote
