Old 08-17-2011, 02:50 PM   #1
Sam-I-Am328
My Ride: 2000 BMW 328i
Question front brake pad replacement guide?
I just sold my E36 n bought a 2000 328i last week n already need to replace the front brake pads. I was hoping to find some info on all the tools I will need and a step by step guide on how to do it. Any tips or info is much appreciated. Thanks!
Sam-I-Am328 is offline   Reply With Quote
Old 08-17-2011, 03:36 PM   #2
Mission2164
My Ride: BMW 323ci
http://www.bmw.lmgtfy.com/?q=diy+fro...t+BMW+328I+%20
Number 2 Doug Domain
Mission2164 is offline   Reply With Quote
Old 08-17-2011, 04:19 PM   #3
paraklas
My Ride: ESS TS2 320ci
Search!!
There are at least 10 threads on a DIY Brake job
Old 08-18-2011, 03:33 AM   #4
jaymemaurice
Location: Anchorage Alaska or Kitchener, Ontario, Canada
My Ride: 01 330ci, 03 Passat
If you are looking for a guide for a brake job, you should probably have a mechanically inclined friend help you, at least for your first job.
Rain Sensor Retrofit: Here
Coupe Headline Replacement: Here
jaymemaurice is offline   Reply With Quote
Old 08-18-2011, 10:02 PM   #5
louie586
My Ride: 2013 ATS 2.0T/6MT
Just replacing your pads? I guess the most important tool is a 7mm hex socket for your socket wrench to remove the caliper guide bolts. You also need a pry bar/screwdriver to compress the caliper's piston back into the bore. If you remove the caliper without compressing the piston first, you can always just use a C-clamp and the old inboard brake pad and compress it that way. Make sure to lube up the contact points (I use Sil-Glyde).
louie586 is offline   Reply With Quote
Old 08-18-2011, 11:29 PM   #6
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Lots of great DIY videos on YouTube.
delmarco is offline   Reply With Quote
Old 08-18-2011, 11:57 PM   #7
jm323Ci
My Ride: 2003 JB M3 Coupe
This should cover the details you seek.
http://m3.madrussian.net/diy_front_brake_pads.shtml
jm323Ci is offline   Reply With Quote
brake, guide, pad, replacement
