///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
Old 08-21-2011, 11:41 PM   #41
Tarmac_E46_M3
My Ride: 2003 M3
Originally Posted by Andy2108 View Post
but it also had a turbo... that cuts down alot on exhaust noise.
when I say delete your fogs, I mean just take them out.
you can get CF brake ducts for the whole fog area though
http://store.bimmerworld.com/e46-car...ucts-p694.aspx
True, but the M has 2 more cylinders, lol. I think if I get the exhaust I'll get the whole "package"; meaning straight pipe and resonator.
I like those brake ducts, i might have to do that, one day.
Thanks for the info thus far!
Tarmac_E46_M3 is offline   Reply With Quote
Old 08-22-2011, 08:31 AM   #42
PerkM3
Account Under Review
My Ride: 2004 SG M3 ESS-550
csl bumper wont get your brakes enough air and they'll get hot fast.
Just delete your fogs and leave the oem front bumper.
I'll be going csl->oem soonish
+1, for a street/light track duty car you would be fine but once you get passed that you will need the extra air.
I have those, they are nice.
PerkM3 is offline   Reply With Quote
Old 08-22-2011, 09:47 AM   #43
Obioban
My Ride: 05 M3, 01 M5, M3iT
Send a message via AIM to Obioban
Here's my weight changes to date. I'm attempting to get it as light as possible without giving up civility.
I'm going to pull the fire extinguisher next spring if I don't have any electrical fires. I just did a bunch of rewiring (and wire removal for weight loss), so I want to make sure nothing goes sound from that, but after that it's coming out.
-Ian
Current Cars: 2005 IR/IR M3, 2001 LMB/blk M5, Wife's 6mt NA RWD e91, 04 M3 wagon
Past cars: 04 M3, 96 M3, S50B32 e36 M3 CM race car
"People do not see good design." -- Claus Luthe, BMW chief designer e30-e39
Obioban is offline   Reply With Quote
Old 08-22-2011, 11:16 AM   #44
PerkM3
I spent like 1 hour looking for your spread this weekend. Thanks for posting, I think this is what the OP is looking for.
Old 08-22-2011, 12:04 PM   #45
Tarmac_E46_M3
My Ride: 2003 M3
That's awesome, thanks.
Some good stuff there to base off of. Sunroof drops 40 lbs from what ive read, correct?
Old 09-12-2011, 05:06 PM   #46
Tarmac_E46_M3
My Ride: 2003 M3
Here's the thread!
2012 MINI Countryman All4
A Compilation of Modifications
Previous: 1969 Mustang, 2006 STI, 2009 STI, 1995 M3, 2003 M3.
Old 09-20-2011, 10:33 PM   #47
Tarmac_E46_M3
My Ride: 2003 M3
The weight my car has lost so far:
Front and left door insulation- 8 lbs
Rear seat insulation- 13 lbs
Navigation Brackets w/storage bin- 3.6 lbs
Rear seatbelts and restraint system- 8.2 lbs
Arm rest mount- 1.4 lbs
Arm rest- 1.8 lbs
center console- 3 lbs
Front door airbags (2) w/ bolts- 2.8 lbs
Front door speakers (both)- 3.4 lbs
Driver seat- 65.8 lbs
Passenger seat- 65.8 lbs
Left door card- 10.2 lbs
Right door card- 10.2 lbs
Left rear seat backing- 25 lbs
Right rear seat backing- 11.4 lbs
Rear seat bench- 12 lbs
Rear seat quarter panels- 4.2 lbs
Left rear door card- 4.6 lbs
Right rear door card- 4.6 lbs
Rear floor mats- 1.4 lbs
trunk mat/ carpet/ rectangle insulation- 10.4 lbs
Total weight dropped: -270.8 lbs
Added weight:
Full Sparco EVO seat +34 lbs
So total loss is at 236.8 lbs. With the second seat in it will be at 202.8 lbs. I still have to take all the tar out and pull a bit more insulation... we'll see where I'm at after that. Hopefully I'll be done by the end of next week.
Old 09-20-2011, 11:07 PM   #48
bimmerfan08
My Ride: F
Nice..eventually after college when I start tracking more Ill get to that point. I plan on keeping the M until it serves its purpose no more
"You are free to make choices. You are not free to escape the consequences."
bimmerfan08 is offline   Reply With Quote
Old 09-22-2011, 10:28 AM   #49
Tarmac_E46_M3
My Ride: 2003 M3
What exactly is behind the blacked out area?
Anyone ever considered a CF dash? There is one on ebay, caliming to weight 2.5 lbs. Apparently stock weighs around 60 lbs; Cost is $1400 I believe. If my math is correct... lbs to dollars that is the best spend weight reduction, even if it only saves 45-50 lbs.
That would be awesome for a track car, like PerkM3. Street car might be tricky- look cool- but will probably need some fabing to keep your vents, stereo, a/c controls and vents... and a few other things.
Maybe it's a far reach... but I think it would be very neat, if it worked out right; it also drops weight from an area that is hard to... the front.
Old 09-22-2011, 11:01 AM   #50
PerkM3
I've thought about it but at this point there were better places to spend the money. The oem dash is heavy as hell though, and it's a good place to loose weight since it's high and up front.
I will go this route eventually but you/I will benefit more from spending 3-5k on a DA suspension then we will with $1,400 in weight reduction.
The only reason I've spent money on weight reduction is because I had to in order to either increase power or increase the safety of my car. All the other weight reduction is free, unless you have the money the free stuff is what you should remove first.
Old 09-22-2011, 11:05 AM   #51
Tarmac_E46_M3
My Ride: 2003 M3
You're right.
I do want to do the free stuff first. Definitely liking the free part! But I might invest in a trunk, maybe even the GTR hood. It's sexy!
Old 09-28-2011, 01:00 AM   #52
Tarmac_E46_M3
My Ride: 2003 M3
Definitely got the trunk and hood... Dropped 29 one total.
Sent from my ADR6400L using Bimmer
Old 11-03-2011, 02:28 AM   #53
Alias206
My Ride: 2004 BMW M3
I believe Dinan still sells 4.10s
Who needs antidepressants when you can drive an ///M3
Alias206 is offline   Reply With Quote
Old 11-03-2011, 08:37 AM   #54
bobm3
Senior Eurowerkz Member
bobm3's Avatar
My Ride: 2003m3smg
guys you all are forgetting these things
back in the 60'ies guys use to take off the fenders and put on fibreglass ones save alot of weight also take out the glass windows put in plastic ones you can save alot of weight their but i dont know how costly those things can be....don't forget glass weights alot compare to the plastic glass
bob
bobm3 is offline   Reply With Quote
Old 11-03-2011, 09:07 AM   #55
Tarmac_E46_M3
My Ride: 2003 M3
bob
Lexan would be neat to have, as side windows (front and rear). Only issue is, how long would they last and could I (or other people) still put their front windows up and down still, when formed to the shape of the stock. Will it cause wear?
I'd be down for it, if it was reliable, like at least 5 years... preferably up to 10 years.
I'd think it would drop a good 20-30 lbs... maybe more.
Old 11-03-2011, 11:32 AM   #56
Martin_BG
My Ride: E46(!!!)
4.10... Where do I find that?!
http://diffsonline.com/product/customdiff3.shtml there you go
Martin_BG is offline   Reply With Quote
Old 11-05-2011, 10:11 AM   #57
screamer-beemer531
My Ride: BMW M3 E46 6spd PY
You can go really extreme on the seats with the HPF 6 lb seat, I don't know how comfortable it is, you can look it up as people have bought them but I do know it's bulletproof, literally They don't look very comfortable but that's as light as a seat can get.
http://www.horsepowerfreaks.com/part...d_Kevlar/17594
"Failure is simply the opportunity to begin again, this time more intelligently." Henry Ford
screamer-beemer531 is offline   Reply With Quote
Old 11-05-2011, 10:49 AM   #58
Tarmac_E46_M3
My Ride: 2003 M3
Seen those... Definitely don't look comfortable. Lol.
That's why I went with the seats I have now. At 10.2 lbs each!!!
Old 12-09-2011, 08:45 AM   #59
Tarmac_E46_M3
My Ride: 2003 M3
Well, as my sig says, I'm now down to about 3070 lbs.
Stock engine (other than pulleys) and stock exhaust. So there is some weight to be had there, once I get around to doing that. I ordered the SS V1 headers, they should be here very soon; just not sure when I'll actually be able to install it.
Right now I just plan on getting tires for my wheels (ARC-8's, 18x9.5) and finding coilovers (used or new) to istall when I mount the wheels. I believe the wheels will drop about 30 lbs; comparing the ARC-8s weight to the stock 19" wheels. I have a CF driveshaft en route as well, that should be another 10 lbs off (according to Obioban ns spread sheet). Now, I would like to run 275 square, but I just don't think -3 degrees camber on a DD is a good idea... So I'm thinking 265 is my best bet. I'm pretty sure I'm going to get the Piliot Super Sports. Any recommendations?
If I'm close to what the next 2 parts will drop, that will put me around 3040 lbs with vac ultra light pulleys, cf driveshaft and Evolve's stage 1 tune. I will also do the foglight delete, read only 2 lbs... but every lb counts! Then maybe find any wires, or really, anything that is literally of no use off/out. I'm sure the fog lights will leave a few wires behind, not much weight, but again it will all add up. I'll be removing the headlight washer things, along with whatever wiring and tubes are on the car, that are not in use. So, Basically the car will be 400 lbs lighter than the standard M3 SMG model (with sunroof); not too bad, I'd say.
After those 2 things... I have to go on a break, lol. Focus on life a bit then start up again mid next year. Once I start again, plan is to get floating rotors (15 lbs off, maybe?) or maybe a good but inexpensive brake kit so I can not only have better braking but lighter calipers too ; get a CF roof (read 15 lbs off); and I've been debating cf front fenders, I'm not really sure how much those actually drop. Those 2 things alone will be quite exspenive, but functional and very cool looking Assuming my guess are right, I should be right around 3010 lbs ( maybe 3005 lbs? with cf fenders?).
Probably take a break for a bit again, make sure all the maintence is good, replace anything that needs to be replaced; and by then I should have basically done any and all free lightweight mods possible. At that point I'll be starting the intall of the airbox, headers, custom exhaust and 288/280 cams. Probably good for another 60 lbs off the car, so that should put the car right around 2950 lbs, full tank.
My guess is by that time, I'll be pushing a good 330 WHP (hopefully more, especially with the cams). If that power is close to what it will be, I'll be sitting at a comfortable 8.94 lbs/HP. In comparision, that's like the stock weight E46 M3 (3415 lbs) having 381 WHP.
I'm bored... which is why I broke it down this much, haha...
Old 12-09-2011, 12:23 PM   #60
lennon31987
lennon31987's Avatar
My Ride: imolarot II M
Send a message via AIM to lennon31987
The dash does not weight 60lbs, maybe 10lbs
Last of the best-
ILLm3 hates me cause im GGGOOODLOOKIIINN
seeking detailing perfection?
lennon31987 is offline   Reply With Quote
