transmission malfuction safe mode - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-19-2011, 04:53 PM   #1
BMWTranny
My Ride: 330xi
After driving for 30-45 minutes or so my car jerks and the transmission malfunction light turns on putting my car into the "safe mode." Also while driving in the automatic D mode the car jerks when shifting into the second gear. So far I have had an oil change, transmissions fluid change and had 2 solenoids replaced (suggested by AAMCO) but yet the problem still occurs. The car is a 2001 330xi. Any ideas what the problem could be?
BMWTranny is offline   Reply With Quote
Old 08-19-2011, 07:03 PM   #2
BmwPerfection
BmwPerfection's Avatar
My Ride: 3.5 M3 & 00 323ci
Send a message via AIM to BmwPerfection
Looks like ur tranny could be going out, but this problem is usually on the 323s and 325s if u have a peake scanner check it for codes if not then have it diagnosed...
BmwPerfection is offline   Reply With Quote
Old 08-22-2011, 05:00 AM   #3
BestOneLeft
My Ride: 3 Series
I have the same problem with mine.
Ran my codes and got
50 Gear check 1
55 Gear check 5
And safe mode code
So far i think its the trans is shot.
Mine only falls into limp mode when i go faster than 65 mph or over 2500RPM
BestOneLeft is offline   Reply With Quote
Old 08-22-2011, 05:07 AM   #4
Stickbuilder
My Ride: Touring, and others
Don't you guys ever do a search function? The safe mode is normally not repeat NOT a problem with the transmission. It is normally associated with fluctuations in voltage. Have your battery and alternator checked out by someone competent.
[/SIGPIC]I'm fluent in 3 languages:
English
Sarcasm
Profanity
Stickbuilder is offline   Reply With Quote
Old 09-22-2012, 08:29 PM   #5
kenken203
My Ride: 328i
a friend and i r having a problem with a 1999 bmw 323i automatic tranny not movin in any gear not slippin just not movin in any gear at all, it will manually go in all the gears at a stand still, but it wont move at all he had a bad battery in it we replaced it after the car wouldnt move figuring it would help but nope its still the same do u think the tranny might b bad or is it in some safe mode the codes r p0101 and p1707 do not have a peake scanner.. anyone have any idea what it might b
kenken203 is offline   Reply With Quote
Old 09-26-2012, 11:46 AM   #6
BestOneLeft
My Ride: 3 Series
Since then i changed my transmission fluid.
Made it noticeably better but still locking into safe mode.
Transmission died 1000 Miles after fluid change (my fluid was dark- change your fluid before its to late!)
New trans was the only repair.
50 Gear check 1
55 Gear check 5
And safe mode code
Old 09-26-2012, 08:24 PM   #7
kenken203
My Ride: 328i
ok well atleast u can drive it mine wont move i guess ill b putting in a tranny huh.. thanks for ur reply..
malfunction, mode, safe, safemode, transmission
