Old 08-21-2011, 02:14 PM   #1
logan01
My Ride: 325i 2001
MAF elbow hose replacement...HELP!
Replacing the intake hose in my 325i and I'm having trouble putting the elbow in. Does anyone know how can you tell that the hose is in place to start tightening the clamps? Or any tricks in keeping the hose in place so that when I start tightening the clamps the hose doesn't keep falling off. It's a tight space and it's the only part I'm having trouble with and obviously about to burn the car down...and I love my car...a lot. Once I get that in; everything else is cake.
Update: Replaced the elbow boot that connects to the throttle body (it was cracked) but now it's idling rough and is making a loud tick, tick, tick sound. Misfire? What can cause this? Loose MAF?
logan01 is offline   Reply With Quote
Old 08-27-2011, 05:11 PM   #2
Loaded325i
My Ride: bmw 325i
Put a light coat of WD40 or motor oil around the lip of the intake boot and rotate it once it is in place. That usually does the trick. The boot is probably not secure thats why your car is running bad.
Loaded325i is offline   Reply With Quote
Old 09-01-2011, 07:27 PM   #3
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
Did my CCV over hual recently and I have the same problem. Because you removed your DISA and the IDE control. You need to replace with all your 'Rubber grommet' you can not reuse them.
BMW /// 323i
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// CCFL angel eye
330i Diff /// REMUS Exhaust /// Heat Shield Cold Air Intake
sellsellsell2000 is offline   Reply With Quote
diy?, intake
