Health & Fitness
Discuss any topics related to heath and fitness here. |
Rating:
#601 |
Thanks for the kind words Glight.
Totally agree with you on the data logging, I just slack on it from time to time. d'oh! |
#602 |
My Ride: 2005 E46 M3 SMG
Back Squat
4x135, 4x185, 4x225, 4x275 4x305 new PR Bench Press 10x95 6x135 4x185 4x190 Dips + Pullups- 10,10,8,8,6,6,4,4,2,2 So happy with lifting 305 today. Just under double my body weight. |
#603 |
Deadlift
135x5 225x5 295x5 335x5 365x3 425x1 |
#604 |
Nice. I'm not even close to that on Deadlift. On Back Squat, do any of you guys use a pad between the bar and your neck? Seems like a lot of weight directly on my spine.
#605 |
#606 |
#607 |
No we're all men here.
#608 |
My Ride: has free candy.
+1
If I'm sore on my spine where the ball sits, I'll let it rest a little further back, sitting mostly on my traps/shoulders. I haven't used a pad/towel on the rack since 9th grade.
![]() embrace this moment remember we are eternal all this pain is an illusion |
#609 |
Ya, I'll try to just adjust the position of the bar next time off my spine to the traps. Thnx
#610 | |
#611 |
#612 | |
I got a massage last week and my back is feeling awesome. Knees are meh, but I think I maybe pulled a lower left Ab muscle a week or so ago. There's some pain when I flex, or when I do some Ab exercises. Didn't hurt when doing deadlift tho. Hockeyman, the comment about back squatting and it being on your spine is one of the major reasons I don't back squat. Putting that much weight directly on your spine is just asking for trouble. I have a few friends that have herniated discs and their lives are hell. I'm not trying to go through that just so I can say I squatted xxx. Unless you're an athlete, leg press will get you around the same size as Back Sq, with less pressure on the joints. Last edited by BMW_Matt; 01-30-2012 at 11:50 PM. |
#613 | |
#614 | |
Make your grip more narrow and it will tighten your upper back so the bar is resting on muscle instead of bone. |
#615 |
I get a rough spot after squatting, but it's not bad. If you have straight up spine pain, you are likely keeping the bar too high. It should sit low on your traps. This also helps center the weight on your body and thus your form will be better.
#616 |
Rough one today.
400m ruck with 100lbs 800m jog with 20lb vest 1600m run 800m jog with 20lb vest 400m ruck with 100lbs 24:17. Brutal. |
#617 |
That is Sick. My Hip Flexors are burning just thinking about a 100lb Ruck
#618 |
#619 |
#620 |
Back Squat - focused on a closer grip and shrugging shoulders to keep bar off spine. Worked better but still slightly sore on one of my vertebrae, not as sore as last time with 4x305.
12x45, 8x95, 8x135, 6x185, 6x225, 6x275 OH Press 12x45, 8x95, 8x115, 6x125 Superset Calf raises & Pull ups 12x135, 12x145, 12x155 8-8-8 Dips - 15 -15 -15 |
| Rate This Thread | |
