Go Back   E46Fanatics > Everything Else > The Off-Topic > Health & Fitness
Health & Fitness
Discuss any topics related to heath and fitness here.
Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 5.00 average.
Old 11-17-2012, 05:36 PM   #1241
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
good strength workout today
hang squats: 3x3: 225/235/245
superset
straight arm plank saws: 3x10
back squats: 3x5: 315/325/345
superset
40" box jumps:3x10
DB incline press: 3x6: 80/85/90
superset
DB rows: 3x6: 110/120/125
pretty happy with the db inclines and back squats actually.
weighed in at 208 at the gym today
BreakMyWallet is offline   Reply With Quote
Old 11-18-2012, 07:29 PM   #1242
BreakMyWallet
BRUTAL workout tonight.
snatch complex
30@ 95LB
30@115LB
30@135LB
60 43" box jumps
I did 5 box jumps every time i stopped with the snatch
so when i was at:
90LB: 10 snatches : 5 box jumps: 10 Snatches : 5 box jumps: 10 snatches: 5 box jumps
115LB: 10 snatches : 5 box jumps: 10 Snatches : 5 box jumps: 10 snatches: 5 box jumps
135LB: 5 snatches: 5 box jumps: 5 snatches: 5 box jumps: 5 snatches: 5 box jumps: 5 snatches: 5 box jumps: 5 snatches: 5 box jumps: 5 snatches: 5 box jumps:
core was on FIRE after. sweating buckets basically. you guys should give it a try.95-115lb were muscle snatches (front the ground) and when io would get tired, power snatch (from the ground)
Old 11-18-2012, 07:34 PM   #1243
M3Inline6
aka...Dark Snow
My Ride: '17 Nardo Grey M4
snatch complex
30@ 95LB
30@115LB
30@135LB
60 43" box jumps
so when i was at:
Damn, that is brutal.
Originally Posted by Qwel on "Manhattan Project"
You heard of me.....burgandy and outlines like murder scenes; Germany..took ferns and flat whites for blurring greens.
M3Inline6 is offline   Reply With Quote
Old 11-18-2012, 07:51 PM   #1244
BreakMyWallet
try it out dude!
and GLight, i didnt do the challenge because this was enough haha. tuesday or wed i will!
Old 11-18-2012, 07:57 PM   #1245
M3Inline6
aka...Dark Snow
try it out dude!
I'm gonna pull out my old soccer shin guards. Nearly everybody I know ends up with nasty shin gouges from box jumps....or....missed box jumps rather (..a lot end up with stitches). LOL! My shins are already scarred up enough. I can't wait to try this snatch complex workout.
Old 11-18-2012, 08:23 PM   #1246
BreakMyWallet
haha. i set it up higher so it basically forces me to jump high. i only fall when i try to speed through lower box jumps. i cought my foot on the second to last one tonight but it was fine i didnt stumble.
btw i did the jumps from a dead stop, not rolling into any of them.
Old 11-19-2012, 12:07 AM   #1247
BMW_Matt
My Ride: 135
I land fully on the box and make sure I do them correctly each time...I'm also trying to get my vertical higher so that's why. I have never liked the "Jump as fast as you can and just nick the edge of the box" jumps
BMW_Matt is offline   Reply With Quote
Old 11-19-2012, 12:38 AM   #1248
BreakMyWallet
theres a purpose for both methods ^
both help with your vert
Old 11-19-2012, 08:34 AM   #1249
DylloS
My Ride: nothing
I'm scared of the snatch. Thankfully not the one that really matters in life lol
DylloS is offline   Reply With Quote
Old 11-19-2012, 11:46 AM   #1250
DylloS
My Ride: nothing
doing this tonight
3x5 Back Squat
3x5 Pause Front Squat
3x5 Press
3x5 Weighted Chin up
21-15-9 reps
105lb Push Press
53lb Kettlebell Goblet Squat
Old 11-19-2012, 12:27 PM   #1251
dabears
My Ride: 2003 BMW M3
Saturday I did a reverse pyramid squat workout...
Warmups (no rest in between)
6x45lbs
6x95lbs
6x115lbs
6x135lbs
6x175lbs (80% of starting workset)
Rested 3 minutes then worksets:
4x225lbs (Felt heavy, stopped at 4 as my form was getting bad... was supposed to get between 6-8)
8x190lbs
12x160lbs
This took me 20 minutes, and I'm still incredibly sore... impressed with quality of workout in such a short time
dabears is offline   Reply With Quote
Old 11-19-2012, 12:34 PM   #1252
BreakMyWallet
Don't be scared of it solly!!!
Old 11-19-2012, 01:05 PM   #1253
DylloS
My Ride: nothing
6x45lbs
6x95lbs
6x115lbs
6x135lbs
8x190lbs
12x160lbs
I like this
I'm more concerned with form as this is probably one of the most technical lifts I'd ever perform. I need some coaching on this one I think.
Old 11-19-2012, 01:26 PM   #1254
BreakMyWallet
Pull like a clean... Then pull more
Old 11-19-2012, 08:07 PM   #1255
M3Inline6
aka...Dark Snow
I need rubber weights damn it. I'm a bit apprehensive about practicing this at my gym.
Old 11-19-2012, 08:41 PM   #1256
BreakMyWallet
just practice with the bar. i still have work to do with mine. i actually went to the gym to practice and ended up doing the whole workout. its hard to snatch it into a overhead squat for me. once i learn to drop under the bar ill be able to put on more weight.
Old 11-20-2012, 11:20 AM   #1257
DylloS
My Ride: nothing
doing the cf wod "grace" tonight
30 clean and jerks with 135lbs. My buddies better check my ass if my form starts getting sloppy.
No idea how long this will take me. I'm post liking turning it into clean and presses
Old 11-20-2012, 12:35 PM   #1258
dabears
this just made me lol at work for no reason
good luck with workout
Old 11-20-2012, 01:51 PM   #1259
BreakMyWallet
just do 5 at a time, rest, 5 at a time, rest.
Old 11-20-2012, 01:58 PM   #1260
Glight
My Ride: 2003 325i
Assuming that weight will get heavy for you as you work through it, pacing is going to be extremely important for you. I would recommend you pic a frequency and do one rep every time.
The first time I did grace in a respectable time I think I set a metronome so that it was beeping every 9 or 10 seconds. It was easy at first but a struggle to keep up by rep 20 or so.
It helped me pace and get a better overall time now.
Best time time now is low 2s. I'm due for another attempt but I'm about to take a week off for the first time in a year.
Sent from my SCH-I535 using Bimmer App
Glight is offline   Reply With Quote
Rate This Thread
