Old 08-26-2011, 01:18 PM   #1
NikkiKrisadtyo
My Ride: 2000 E46 BMW 318i
Help with draining Radiator
Hello, Bimmers all over the world.
I'm new to this forum. I'm new to BMW. A welcome hug? No?
I'm from Indonesia, anybody from Indonesia? 'Sup?
Anyway, I just got a 2000 318i. Had a bit of tidying up to do. Like fix the electronics, dents, etc. And I just changed the standard 15" to 17" ten spokes, giggity! So far so good. A few days ago my family and I were having a little road trip up the mountains. And after we'd gotten to the top, sort of, the temperature was over the top. There was steam coming out of the radiator cap, after it had cooled down we refilled it with water. Later, after we got home I found out that the seals in the cap were, well, gone, hence the steam. After replacing the cap I'd like to take preventive measures and drain the water in the radiator so I can refill it with radiator coolant.
So here's the problem, I expected to see a bolt of some sort under the radiator to let the water out. But I saw nothing but a plastic cover underneath the radiator. So, anybody know how to remove said plastic cover and drain the radiator so I can refill it with radiator coolant DIY style? I couldn't find a threat that was helpful so I posted this. Thanks beforehand!
- Nikki Krisadtyo
NikkiKrisadtyo is offline   Reply With Quote
Old 08-27-2011, 05:09 PM   #2
Loaded325i
My Ride: bmw 325i
Sure, you have to remove that plastic sheith. The bumper tabs can be plucked off with a screwdriver, and the screws along the side can be take off with a philips screw driver. Once you take it off, there should be a blue drain plug there.
Loaded325i is offline   Reply With Quote
bolt., diy, drain, radiator
