Old 08-29-2011, 08:39 AM   #1
everchini
My Ride: 2000 323Ci
Angry Car Overheated, Coolant brown milky mixture, radiator or blown head gasket?
Hi everyone,
Just bought this car about 9 months ago, and everything has been fine with it until I was driving yesterday and the coolant light came on for a second (I didn’t know what it was at the time but the light went off a few seconds later).
I parked my car got what I had to in Target and tried finding out what the symbol meant. On my way back the same coolant symbol came on and then my car started to overheat. I quickly pulled off to the side of the road, opened the hood and there was a brown milky mixture all over the bottom of the hood and all in the engine compartment.
I opened the coolant cap and it was empty but was not clean at all, it was the same brown milky consistency (I haven’t filled or drained the coolant since I got the car)
I asked my friend who is BMW certified and he says it’s the head gasket that is blown but the car runs fine if you put water and coolant in it. I brought it to a uncertified mechanic down the road and he thinks its the radiator that needs to be replaced.
The engine and dipstick oil looks the way it should be and the same milky consistency isn’t in the engine.
WHAT SHOULD I DO? Replacing the head gasket was priced at 18 hours roughly $1500 on top of parts...
everchini is offline   Reply With Quote
Old 08-29-2011, 08:41 AM   #2
//TRD power
My Ride: 3.0 | 200hp | 214trq
Run a clean coolant mix, and check it after a day. Maybe the previous mixture was brown for some reason.
The head gasket takes under an hour to do, and the part isn't expensive. Where did you go? Kia dealership?
//TRD power is offline   Reply With Quote
Old 08-29-2011, 08:42 AM   #3
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
My friend did the same thing, I replaced his upper radiator hose, filled and bled the system and his ran fine.
Usually thats a really bad sign, but somehow his car ran just fine and had no problems. He ended up getting rid of it a few months later but it ran just fine up until then. So not sure how it ran in the long run.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 08-29-2011, 08:43 AM   #4
330ciandr6
My Ride: .
I'd like to see this.
Old 08-29-2011, 08:44 AM   #5
makecopies
My Ride: 325ci / 350Z / LS400
He must be thinking Valve Cover Gasket
makecopies is offline   Reply With Quote
Old 08-29-2011, 08:51 AM   #6
everchini
My Ride: 2000 323Ci
Ok thanks you guys, whose thinking valve cover gasket? My friend said, the Head Gasket.
Old 08-29-2011, 08:58 AM   #7
CylonRed
My Ride: '01 E46 330i sport
TRD Power said a head gasket could be replaced in about less than a hour - no way. Folks were just pointing out that a valve cover gasket could be replaced in about an hour and that is what TRD Power was likely referring to...
CylonRed is offline   Reply With Quote
Old 08-29-2011, 09:01 AM   #8
everchini
My Ride: 2000 323Ci
Oh yeah, I don't know where he got valve cover gasket from
Old 08-29-2011, 09:21 AM   #9
jgold47
My Ride: 2004 X5 3.0
the only thing to keep in mind is that if the PO used Zerex - G-05 which is an approved coolant, its more of a beer color, which when it gets dirty would probably turn brown. When I did mine between the Zerex, the Blue and and Green it was quite the interesting color. That said, milky is another problem i suppose unless you had the totally wrong coolant. I would maybe try a cooling system flush and overhaul, including a new water pump and thermostat and see. If you blew your head gasket (IIRC) you would have oily coolant, shitty power, and a lot of smoke.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 08-29-2011, 09:28 AM   #10
//TRD power
Oh yes sorry was thinking valve cover. Oops.
Old 08-29-2011, 09:36 AM   #11
everchini
My Ride: 2000 323Ci
thanks jgold, would I be able to install a water pump and thermostat on my own or is there a lot of programming that needs to be done after the installation?
Old 08-29-2011, 09:37 AM   #12
BMW-North
My Ride: 325cic, 330i, 330xi
Drain all the coolant from the engine block plug (enough DIY's on here) - check for oil in the coolant.
Drain all the oil - check for coolant in the oil
In both cases the visible signs will be a milky brown streak through the liquid
If you find it in either I would suspect the head gasket blew when the aluminum head got too hot.
If you suspect the head - go to a local shop and have them to a pressure test.
Changing the head gasket may not fix this - if the head warped from the overheating.
There are lots of threads on here about overheating including mine (325 cab)
I was lucky and the head did not warp - others have not been so lucky.
I will attach a PDF that is a BMW SI for checking the overheating damage of the E46.
Typically if this pipe is melted BMW determine that there was sufficient heat from the ovberheating to cause substantial engine damage.
BMW-North is online now   Reply With Quote
Old 08-29-2011, 09:43 AM   #13
Y34RZ3R0iscoming
My Ride: 2002 E46 M3
OP... is ur sig car on OZ Energy's?
(not trying to threadjack lol just curious)
Y34RZ3R0iscoming is offline   Reply With Quote
Old 08-29-2011, 09:46 AM   #14
everchini
My Ride: 2000 323Ci
Are you talking to me? Idk what OP means or 'sig' or OZ Energy or threadjack
Old 08-29-2011, 10:42 AM   #15
RockLee
My Ride: 99 328i. ZSP, ZPP,
Send a message via Yahoo to RockLee Send a message via Skype™ to RockLee
1999 328i Sport Package, Premium Package, 5 speed, Alpine white.
RockLee is offline   Reply With Quote
Old 08-29-2011, 10:45 AM   #16
Shmo
My Ride: 2000 323i
Send a message via AIM to Shmo Send a message via MSN to Shmo Send a message via Yahoo to Shmo Send a message via Skype™ to Shmo
BMW North beat me to what I was going to say.
However in the event you find your car overheating again, do the obvious and pull off to the side of the road. Instead of turning the car off all the way, keep the key in position 2 and turn the heater on high. This will help the engine cool and may even save a few people from getting warped heads.
You did pray to your BMW shrine first, asking the Great Roundel for guidance on parts' choices first, right?
Shmo is offline   Reply With Quote
brown, coolant, exploded, head gasket, overheated
