///M3 Forum
The BMW E46 ///M3 is the M version E46 and puts out an amazing 333 HP and 262 lb-ft of torque at stock specs! There are an amazing amount of modifications for both the coupe and convertible models so read up and get started modifying your cars today! |
#161 |
Thanks! I'm doing what i can!
This battery has done fine for me so far, but it's only been in the car since this afternoon. I don't have a stereo, so I can't say if it will work well or not... but, i'm pretty sure, as long as you're not in below zero weather, it will hold up just fine to daily use. If you are leaving your car for a week, I'd just disconnect it, that's what i will do.
Current: 1969 Ford Mustang; 351w; Champion 4 row alu rad; Edelbrock Intake Manifold; Holley 600 CFM Carb; Cragar Wheels; 215/60-15 f, 255/60-15 r; Doug Tri-Y Headers; Dual Side Exit w/Xpipe; MSD 6AL; Electric Fuel Pump; U/D Pulley Set; Monte Carlo Bar.
SOLD: :( E46 M3 SMG; Evolve-R Tune; much, much more... 2980 lbs. ![]() Home biz info: www.HelpMeFightTheForcesOfEvil.com |
#162 |
E46 is strong with this one
Paint those aluminum sheets ASAP....
#163 |
Read the thread/post ASAP!
#164 |
Have been, yo
#165 |
Then your post is irrelevant; I already stated I'm going to wrap them.
#166 |
did you just get rid of side airbags and replace them with sheet metal?!?!?!?!
i dig your enthuse to have a really light car, but to get rid of airbags?!?! you might as well pull your steering wheel out and replace it with a lightweight one, after that you should pull your headlights too, those things can sure add up in weight... |
#167 |
Whered you get the battery from?
#168 | |
#169 |
Amazon, battery mart I believe. You just type the battery name in google and a bunch of sites will pop up.
#170 |
Ever hear of Dyna-Batt? 13.5 lbs
#171 |
I believe so.
Issue is, i dont want to small of a battery to where I start having issues.
#172 | |
Gotcha. Was thinking the same thing.
#173 |
Just flashed my ECU with the Evolve-R stage 1 map, with every bell and whistle (8150 RPM!).
That along with the CSL SMG map programmed makes the car feel awesome. Pulleys definitely help too, make the response from the pulleys feel amazing! Once I install the CF driveshaft (hopefully soon) I should feel another noticeable increas in response and maybe a tad bit of power. After that I really need to attack the suspension area. Sitting at 3073 lbs makes the car sit high on the stock suspension. Cool thing is... once I get coilovers, my car will be extremely similar to a CSL Power and feel wise.
#174 | |
sweet man, sounds like its coming along....
![]() '02 Ti Silver M3 SMG SoCal I.E. Mods: 35% Ceramic tint, CF Wrap Interior, CF roundels, CF Shift Knob, Painted reflectors, Cell Phone holder, Euro mirrors, Dice Mediabridge, Sirius SC-C1 IHAZBMR's '02 M3 SMG |
#175 |
Sure is... Can't wait for the next 2 parts.
Sent from my ADR6400L using Bimmer
#176 |
Past Site Sponsor
Looks like she's coming together, can't wait to see your plans come together.
#177 |
Past Site Sponsor
#178 |
SOLD: :( E46 M3 SMG; Evolve-R Tune; much, much more... 2980 lbs. ![]() Home biz info: www.HelpMeFightTheForcesOfEvil.com Last edited by Tarmac_E46_M3; 11-28-2011 at 08:41 PM. |
#179 |
Short (kinda) term goals:
- Install CF driveshaft - Wrap interior in Matte Black - Coilovers/Alignment - Lightweight flywheel (if anyone can help me in this area, not sure which ones work with the SMG; if there's a difference) - CF roof
#180 |
Anyone have some good input on cams?
I'm reading the 288/280 Schrick cams are a good upgrade for the stockers. What about throwing in some 304/296? Too hard core maybe?
