Old 08-30-2011, 09:05 AM   #1
Sharif_M5
My Ride: BMW 330ci e46
Parking sensor
My parking sensors aren't working at all as when I put it in reverse first time I get a long beep noise an then goes off. What could be the problem? I'd appreciate any help possible. Thanks
Sharif_M5 is offline   Reply With Quote
Old 08-30-2011, 09:46 AM   #2
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Did your car come with parking sensors? or are you assuming it should be there?
Sometimes bumpers are replaced with non original bumpers that have stuff that the car did not originally come with.
Could be the wiring is faulty somewhere, or the ecu for the parking sensors need to be replaced
delmarco is offline   Reply With Quote
Old 08-30-2011, 10:09 AM   #3
ECSTuning
ECSTuning's Avatar
My Ride: BMW
They tend to collect water past the head of the sensor. Past the seal.
If you don't hear the small ticking noise close up to the sensor when in reverse, then you know which one is bad.
They come in stock black plastic.
*If you need them in factory BMW color , they come pre-painted, otherwise stock black.
Thanks and I hope that helps.
Joe
ECSTuning is online now   Reply With Quote
Old 08-30-2011, 11:29 AM   #4
Sharif_M5
Delmarco
My car comes originally with the sensors. I mean it was perfectly fine till today morning. So you think it could be just the wire or one of the sensors?
Old 08-30-2011, 11:30 AM   #5
Sharif_M5
ECSTTuningJoe
Ok so I listen out for the one without the ticking noise to see if there's a bad sensor?
Old 09-01-2011, 09:06 AM   #6
Sharif_M5
[QUOTE=ECSTuningJoe;13535106]They tend to collect water past the head of the sensor. Past the seal.
Joe
I have listened to the sensors while the car is in reverse and I hear ticking noise from all of them. What does that mean then?
