E46 Xi Forum
Old 08-30-2011, 10:22 PM   #1
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
325xi Instrument Cluster
Looking for some help on my 2003 325xi Instrument Cluster. All of a sudden, nothing in the cluster works (except for ABS lamp and Seat Belt warning lamp): no tach, speedo, water temp, fuel, car icon, battery, back lights of cluster, OD, Trip OD, clock, etc. Fuses 10, 34 and 43 checked (all checked ok), but replaced with new fuses (didn't solve problem), all other fuses were also check. Car starts and runs perfectly, door locks, seats, windows, A/C, Heat, defogger, radio, turn signals, 4 -ways, all exterior lights work; just nothing in the cluster. Anyone experience this before? The "High Amperage Fuses" located above main fuse block were not checked as according to Bentley, should have no bearings, so relays were checked, again as everything on a relay works and thus should have no bearings. (The E-Box fuses were checked and all tested ok, but they also should have no bearing on the problem).
I'm suspecting 1 of 2 things at this point; a firmware problem (some how it got partly skewed), or a major failure of the instrument cluster printed circuit board.
Shows no fault codes; - - after running Fc test with Bav Auto Fault Code Reader.
Prior to this (car was used yesterday, Tuesday and problem was seen today, Wednesday) everything on car worked and worked correctly, no fault codes, no check engine or service engine lights.
Those with insight can respond directly to: tomoyer@verizon.net
tomoyer is offline   Reply With Quote
Old 08-30-2011, 11:27 PM   #2
My325XI
My Ride: 03 325XI Sprt Prem
Try the cluster test out yet...
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 08-31-2011, 06:31 PM   #3
tomoyer
Thanks for the reply. I watched the video and then went to the car, turned the key to the second position and held the left button for several seconds, nothing happened at all. Not sure what to check next with this problem!
Old 09-06-2011, 04:00 PM   #4
tomoyer
Update on Dash Cluster not working; did the dash cluster test a second time and all lights and gauges functioned. Rechecked fuses including the 3 for the Instrument cluster and those for the ABS system, all ok. Pulled cluster out and cleaned and re-seated the 2 wiring plugs. Upon starting the car and taking for a short test drive, everything works with the following exceptions; Speedo, Odometer, Trip and Mileage Gauge. Possible bad sensor and/or too much moisture in plug? (have not had time to check as it has been raining cats and dogs here the last 3 days)
Is the speed sensor on the rear diff like E30s or is it using one of the ABS sensors, doing double duty? Not too clear in Bentley Service Manual.
Old 10-18-2011, 08:43 PM   #5
ronster206
My Ride: BMW 325xi
im also dealing with the same problem. i have a BMW 325 xi. let my car sat for 3 weeks. started my car, and found any of the guages not working in instrument cluster. the only light is the ABS and airbag lamp. ived check connection (2 harness)to the rear cluster and 3 fuses to glove box. no defect found. im also thinking maybe moisture got into the connection to cluster?? its been cold and rainy here in seattle. TOMOYER haved you figure it out>? any body experiencing the same>>? or tips? ideas? i all ready tried the cluster test. no luck.
ronster206 is offline   Reply With Quote
Old 10-18-2011, 08:57 PM   #6
tomoyer
I was getting some moisture in the car and it was making for poor connections at back of cluster..........removed both wiring harnesses, dried them out and used contact cleaner to clean them and no problem since.
Old 03-14-2014, 02:25 AM   #7
hiroxbmw
My Ride: 325xi
i just wanted to say i had the identical problem on my 2003 325xi manual. i replaced the vanos seals, but snapped vanos retaining bolt. the car sat for a couple of weeks waiting for replacement parts. when i got everything back together, the entire instrument cluster was dead (no odometer / tach / lights EXCEPT ABS and airbag).
the car was outside in the rain, with the hood closed but not latched, and i did notice some water under the hood and even a small amount in the glove compartment. fuses for the instrument cluster looked ok, disconnected and reconnected the battery and the car started ok. i let the car dry out for a week, but still no instrument cluster. i pulled out the instrument cluster and noticed the xenon headlights would occasonally turn on by themselves when i plugged the connectors on the back of the instrument cluster back in.
finally found some threads suggesting a weak battery can cause all sorts of electrical gremlins, especially affecting the instrument cluster. i considered the possibility that the battery weakened over the two weeks the car was not in use, and replaced it. happily, that fixed the problem. i favor this as the final cause over wet connector in my case.
just wanted to add to this thread because the solution wasn't particularly obvious, and there a number of odd instrument cluster problem threads that seem to have wound up fixed by replacing the battery. i even went so far as to find a used instrument cluster on ebay for $50, but did not need it.
hiroxbmw is offline   Reply With Quote
Old 03-20-2014, 04:46 AM   #8
ronster206
My Ride: BMW 325xi
325xi instrument cluster
Thanks for sharing . I went and removed the instrument cluster again and this time i removed the connection from behind and sprayed the connector with electric cleaner then smeared dielectric grease . Then plugged it back in...then it worked!!!!!!!!!. Drove me crazy for the longest. I was almost going to buy a instrument cluster for $1500 I think moist/wet got in. For some reason after ... I never had a problem since. I think oh it happened was I let my car sat out in the rain... And my weather seals were worn... Ive notice my carpet would get wet every time ...
Old 03-20-2014, 04:49 AM   #9
ronster206
My Ride: BMW 325xi
Oh by the way....thanks to tomoyer. (Instrument cluster inop. Abs, airbag light only on) fixed!
Old 03-21-2016, 11:42 PM   #10
dragondrpr
My Ride: 03 325xi
lol still helping people out yes!
dragondrpr is offline   Reply With Quote
Old 03-25-2016, 02:53 PM   #11
dragondrpr
My Ride: 03 325xi
None of this worked for me....but I know I caused it to happen while I was messing with my audio system ....I disconnected the negative power but the battery was still grounded through cap farad dropped a wrench on the positive and negative and now my cluster is down....I tested all the plugs and fuses ....with my meter haven't tested the board yet.....what does anyone know about this.... ....its only 4 bucks ....
Old 03-25-2016, 05:48 PM   #12
dragondrpr
My Ride: 03 325xi
I made a video testing the little sucker and 2 of the pins are bad
Old 05-27-2016, 05:09 PM   #13
Swagkc
My Ride: 2003 325xi
have you repaired the elms chip yet? I having similar issues to this. I found this video on youtube and in this forum, what are your thoughts?_nr_
Swagkc is offline   Reply With Quote
