Old 08-31-2011, 11:58 AM   #1
DukeofNuke
My Ride: 2002 325i
Another Non-Starter
2002 E46 / 325i
It starts occasionally. I left it at my mechanics for three weeks, and he said it started every time. I brought it home, and it wouldn't start after two hours of driving. This has been going on all summer.
I replaced the battery,
I replaced the fuel pump.
Still, it sits there going dadadadadadada when I try to start it.
Sometimes I can put booster cables on it, and it will start after a couple of minutes, but this is with a new battery. Once it starts, it runs till you turn it off, then back to square one.
Error codes are:
P0171 System too Lean (Bank 1)
P0174 System too Lean (Bank 2)
My mechanic says that wouldn't keep it from starting.
I have considered the camshaft position sensor, but there is a OBD code for that, and I'm not getting it.
Any Ideas ?
Thanks.
DukeofNuke is offline   Reply With Quote
Old 08-31-2011, 12:43 PM   #2
Zchild
My Ride: 2000 BMW 3XXi ZSP
If indeed your car started and you drove it for two hours and came home and it wouldn't start I would have to say your alternator for some reason isn't charging your battery. It could be as simple as a bad ground either in the trunk or under the hood. Have your alternator checked at your nearest Checker Auto or AutoZone. Just my two and a half cents worth...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 08-31-2011, 12:48 PM   #3
Loose_cannon
My Ride: 2001 325ci
since your car isn't giving you the cam position sensor code, i don't recommend wasting your money on that. I have the same problem, something is draining my battery and it was on and off. So my mechanic came to my house and we got a cam position sensor code, so he called another friend to see if that could be it, apparently it's called a pulse generator in the realoem catalog and it somehow interacts with the spark plug and that could maybe me the problem...well i bought it, we changed it, and my car still dies on occasion, now i'm getting a MAF code....
Loose_cannon is offline   Reply With Quote
Old 08-31-2011, 01:00 PM   #4
MF325XI
My Ride: '03 325XI
+1 on having the battery/charging system checked at autozone. mine was doing similar things, replaced the battery and it seemed to be starting slow. Turns out the starter was bad. If you can eliminate the Alternator being the issue my guess is starter. Good luck cause the Starter is expensive and a PITA if you do it yourself!
Winter mode
MF325XI is offline   Reply With Quote
Old 08-31-2011, 01:08 PM   #5
DukeofNuke
My Ride: 2002 325i
I did that, and they said the starter and alternator checked out OK.
Old 08-31-2011, 03:43 PM   #6
MF325XI
My Ride: '03 325XI
Not sure how they can really test the starter without pulling it out of the car.... My bet is still Starter. what kind of voltage do you get at the battery while the car is running (should be around 14.5 volts) ? HOw many amps is the alternator pushing?
Did you replace the fuel filter as well? That is cheap and easy to do and probably needs to be done anyway, it has the fuel pressure regulator built into it so that could be a cause.
Has this car overheated recently or any mods done prior to this issue? You should have a compression check done to make sure it isn't something in the engine (pretty unlikely since the car does run). Also, check all wiring to make sure it's tight and now corrosion.
Winter mode
Old 08-31-2011, 03:58 PM   #7
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
is it cranking and not turning over?
sorry don't know what dadadadada means
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 08-31-2011, 05:08 PM   #8
DukeofNuke
My Ride: 2002 325i
Yes, it cranks but does not start.
Sorry, dadadada is my best written impersonation of the sound.
It does not "click, click, click", as a dead battery. The starter runs, but it does not "catch".
I did not know that. Hmmmm.
It sure acts like it's not getting fuel, but I can screw-up changing the oil in a lawn mower, so what do I know ?
Old 08-31-2011, 06:00 PM   #9
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Use advanced/title search.
There are other little things...sap failure might do this when engine is cold. Try another key...but search 'no start' threads...you'll have a long list of possibles.
Work simple and easy to check ones first. It does sound like battery, though, even though it's new. Did you have it checked at the place you bought it from? If so, maybe they just say this hoping you go away for a while and maybe get a new alternator...not to accuse them of faulty diagnosis or anything!
Get multimeter or do cluster test.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 08-31-2011, 09:34 PM   #10
dirsh
Hawaii 3.0
dirsh's Avatar
do you hear the fuel pump priming? If not, it could be the fuel pump relay. Swap it with the horn relay to test. easy and free test
when my fuel pump relay was going out, I would have to turn the key on and off (not cranking) several times before the fuel pump would kick on.
Old 09-01-2011, 09:25 AM   #11
DukeofNuke
My Ride: 2002 325i
I'll give this a try
Unfortunately, the car is at my sons house, 2 hours away (that's where I was when it quit). I'm hoping to get it to start like it sometimes does to get it home.
