Old 08-31-2011, 04:48 PM   #1
rickbrum
My Ride: 1999 e46 318i
wheel fitment
iv put e90 alloys on my 1999 e46 they fit but the front wheels handleing is all over the place having to fight it to keep in a straight line.they are 17 inch with 225 45 tyres on
rickbrum is offline   Reply With Quote
Old 08-31-2011, 04:50 PM   #2
polychrome
My Ride: 2002 325i
You're probably experiencing what is often called "tramlining." Get your wheels aligned.
polychrome is offline   Reply With Quote
Old 08-31-2011, 05:12 PM   #3
rickbrum
wheel fitment
iv put e90 alloys on my 1999 e46 they fit but the front wheels handleing is all over the place having to fight it to keep in a straight line.they are 17 inch with 225 45 tyres on they this stick out more wider is this anything to do with the tramling
Old 08-31-2011, 05:15 PM   #4
rickbrum
the wheels stick ut more wider is this adding to the tramling
Old 08-31-2011, 05:26 PM   #5
rickbrum
thank you for your help
Old 08-31-2011, 05:30 PM   #6
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
first check for tire pressure, balance, bends and treadwear.
sometimes a bad treadwear on tires can cause the pull.
depending on what you orig. had on the car, a bigger wider wheel/tire can accentuate a problem that was already present in your suspension or allignment that you didn't realize was there.
I have a e46 sedan with 18" sport wheels from e90 330 with no problems... also I put 12mm spacers in front & rear... still no problems.
Bimmer4Lyfe is offline   Reply With Quote
Old 08-31-2011, 06:30 PM   #7
azshorty
My Ride: Hellrot 323CI
Control arm bushings. Had the same issue on 18x8.5 up fronts. Replaced bushings and the wandering went away.
I kind of liked it though.
azshorty is offline   Reply With Quote
Old 08-31-2011, 06:44 PM   #8
azshorty
why are there two threads?
Old 08-31-2011, 07:45 PM   #9
chivo328
My Ride: 328/330/633/M5
Try this thread, I believe he may be experiencing the same problem you are. http://forum.e46fanatics.com/showthread.php?t=867414
chivo328 is offline   Reply With Quote
Old 08-31-2011, 07:46 PM   #10
azshorty
im no longer experiencing anything since replacing
lcab's
